DA Integra Check Engine LIght Question
Old Mar 15, 2010 | 03:14 PM
to4e hatch's Avatar
Default DA Integra Check Engine LIght Question
I have a 93 Integra with a 1.8 LS. I am getting a code 43. this is a fuel delivery issue. The car seems to run fine under throttle and the only hiccup seems to be at idle. Every once in a while has a slow idle accompanied by a slight misfire. I have put new injectors and computer in the car but that didnt seem to fix the problem. Any input would be greatly appreciated.
Old Mar 15, 2010 | 10:01 PM
dc4johnrhdeg's Avatar
Default Re: DA Integra Check Engine LIght Question
Check your battery grounds, and check for a vacuum leak. Ofcourse if you havent changed your fuel filter, now is a good time.
Old Mar 16, 2010 | 09:13 AM
to4e hatch's Avatar
I have checked the vacum lines and i havnt ran across any bad grounds that i have seen i am gonna replace fuel filter but i dont think thats it cause it dont act like its clogged when you blow air through it i was just wandering if any one else has seen this and what they did to correct it
Old Mar 18, 2010 | 05:47 AM
to4e hatch's Avatar
O2 sensor fixed it thanks for any help or input that anyone gave.
thatguamanionkid
May 16, 2009 11:13 AM
inside0ut
Aug 30, 2008 08:52 AM
hon2984
May 4, 2008 12:57 PM
DSeriesBeeKilla
Nov 14, 2002 12:33 PM
integraautox
Oct 20, 2002 08:21 PM
