b20 vtec... help needed
Old Mar 24, 2010 | 05:38 PM
owen23's Avatar
Default b20 vtec... help needed
have a b20/gsr head. it runs good most of the time but on ocassion it will start sputtering (around 4k) but i can feather the throttle and it will all the suden stop sputtering around 4500/ 5k rpm. it mostly happens on the freeway when im in fifth gear, i can downshift and it goes through the powerband fine. also somtimes when im at idle will bounce and sputter out. im changing plugs, wires, and cap this weekend. anyone had this problem? any advice welcome.
Old Mar 24, 2010 | 06:17 PM
v.ice1's Avatar
Default Re: b20 vtec... help needed
change the plugs and stuff then go from there sinds like ignition to me i got ls/vtec
Old Mar 24, 2010 | 07:33 PM
madblkscientist's Avatar
i had the same problem, it was my injectors and now it idles/revs good
Old Mar 24, 2010 | 08:10 PM
owen23's Avatar
well i should have enough money this payday to get my ignition taken care of as well as some new injectors + seals. any ideas on what size would be ideal for my setup? i would like somting that would be plug and play due to the fact i dont have a ecu to tune it yet. i dont mind if they will need to be upgraded at a later date i just need somting to keep my hatchie running good. gsr cams/ stock b20b block/ will be installing my skunk2 intake mani/ stock gsr throttle body/ gsr header / crowder springs and retainers./ bdl fuel rail (no regualtor yet). would 310 cc be to big?
i was guessing it was ignition/ injectors/ or a valve sticking . everything will be replaced eventually but just like many of us times are hard and $$$ is tight.
i know these are some noobish questions but thank you for your replies
Old Mar 25, 2010 | 10:51 AM
240cc is stock, type r inj are 260-270 i think, i dont know if the 310 will work good without a tune.
Old Mar 25, 2010 | 11:57 AM
mouab18c1's Avatar
Are you sure? I thought all stock injectors were 240cc
Old Mar 25, 2010 | 12:21 PM
thats why i said i thik not positive. i heard they r like 10-20cc more
Glehman1
Mar 23, 2012 03:36 PM
94dxeh2
May 24, 2011 09:21 AM
egcrew02
Jan 16, 2009 07:23 AM
95GSRDC2
Sep 5, 2007 06:00 PM
