fuel gauge issue
Old Mar 22, 2010 | 06:41 PM
EFresh's Avatar
Default fuel gauge issue
i recently purchase a crx last month+. i got it with a half tank and drove it out to get rid of the old gasoline. gauge shows that im pass E but when i fill up, taps off at 9 gallons. from factory spec my tank is about 12 gallons. i usually leave my key turn so that my gauge will increase while pumping. it stops 3/4 the way but after start up, gauge goes all the way to the top. so im guessing that the gauge could be malfunctioning? or maybe my gas tank? or fuel pump?
Old Mar 23, 2010 | 11:52 AM
delsolproblems's Avatar
Default Re: fuel gauge issue
You'll want to check the fuel level unit. You check the resistance across the left two of the three terminals of the unit with the float in various positions- lowest position for empty tank reading, mid and top positions. Empty reading is 105-110, half reading is 25.5-39.5 and full reading is 2-5 (Ohms). Also make sure the float is moving freely.
Jar-Head23
Jun 5, 2009 08:36 PM
macdaddydelux
Honda Motorcycles
Oct 10, 2007 01:43 PM
iixerOii
Oct 5, 2004 03:35 PM
90lsteg
Apr 1, 2004 12:06 PM
