Cometic Headgasket instillation necessities: What NEEDS to be done?
Old Mar 12, 2010 | 02:52 PM
Romo Pyro's Avatar
Default Cometic Headgasket instillation necessities: What NEEDS to be done?
Im going to be installing a new cometic head gasket on my motor, the motor is still in the car, and I know for sure the head will be resurfaced, but is it COMPLETELY necessary to deck the block as well. Im only concerned because I have a limited amount of time I can be without a car, and this HAS to be done. So I need to know if I need to remove the engine from the car in order to get it decked or not.
Old Mar 12, 2010 | 03:21 PM
Romo Pyro's Avatar
Default Re: Cometic Headgasket instillation necessities: What NEEDS to be done?
Can I get a bump?! HOOAHH!
Old Mar 12, 2010 | 04:27 PM
Romo Pyro's Avatar
VUMP IT VUP MAHN!
Old Mar 12, 2010 | 05:04 PM
Romo Pyro's Avatar
omnomnom
Old Mar 13, 2010 | 11:19 AM
postman's Avatar
you can check the block yourself with a straight edge while its still in the car. usually the block is ok unless some carnage took place of some sort. as far as installing a new gasket just be sure to tighten to proper torque and sequence.
Old Mar 14, 2010 | 08:09 PM
Romo Pyro's Avatar
Ok, sounds good.
hatchet_honda
May 16, 2009 02:28 PM
W O T
Feb 13, 2005 10:06 AM
TeamCracka
Feb 16, 2004 06:34 PM
Prelude Vtec 23
May 15, 2003 08:12 AM
