95 Civic Wierd Hot Start/Idle Problems
Old Mar 24, 2010 | 06:41 PM
awdgsx96's Avatar
Default 95 Civic Wierd Hot Start/Idle Problems
Ok guys, I have a 95 Civic coupe with a D15B7, auto if that matters.
Sometimes on hot starts, the car will idle at normal range, but sounds like it is misfiring, almost like a Subaru. It never happens though if I turn the car off, then quickly turn it back on. Only when it sits for about 10 mins. When it happens, sometimes it goes away and idles normal, sometimes it lingers, and sometimes when I give it gas, it puffs smoke and goes away. The car always drives fine afterwards.
I'm stumped as to what it is. I was thinking headgasket, but the car doesn't consume coolant, it has fine heat, and there is no coolant in the oil. I replaced the cap and plug wires, and it seemed to help for a while, then the problem comes back. I guess it could have been chance.
So now, I don't know what to think. My dad says maybe the battery is dying, and is straining alot on a hot restart, and can't keep the motor running. Or I think that maybe the Engine Coolant Temp Sensor is going bad, thinking it's cold and dumping alot of fuel.
None if this happens at all if the car is cold. I'd appreciate any input, especially if any OG's could chime in
__________________
Old Mar 25, 2010 | 07:40 AM
delsolproblems's Avatar
Default Re: 95 Civic Wierd Hot Start/Idle Problems
First check your grounds, preferably with a meter. You can check the TB, IACV and FITV, cleaning any dirty parts. You can borrow a fuel pressure tester from a parts store and check the fuel pressure with the regulator vacuum hose both connected and disconnected. You could also test your spark at each wire and/or have your ICM and coil tested at a parts store.
95TeggyRS
Mar 18, 2018 10:44 AM
PnutButterCup
13
Jan 16, 2016 04:15 AM
frostykue
Jan 22, 2011 12:49 PM
awdgsx96
Mar 23, 2010 06:13 PM
dividedas1
Mar 1, 2007 05:42 PM
