Electrical help please (should be easy)
Old Mar 12, 2010 | 07:46 AM
civic sand rail's Avatar
Default Electrical help please (should be easy)
Hey people,
Ok,,,,, I'm building a sandrail and need some help with the tach.
I have an aftermarket tack and i am installing it in the sandrail. I had read around the internet for a while and it seems as though most people are hooking up there aftermarket tack signal wire in the dash. As i do not have a dash I need to know which wire i need to use
Details.............
I have re-worked the wiring harness and everything is working great! I obviously do not have the same dash as the 1996 civic.
My first question is--------------- What wire on the distributor do I connect the signal wire to?(See pic) OR which wire on the computer
Second question is--------------- Is the signal coming from the distributor 12V? I did hook up the tack for a second to the blue wire on the bottom and it spiked the tack momentarily.
Thanks in advance!!!!
Steve
Old Mar 12, 2010 | 09:09 AM
EE_Chris's Avatar
Default Re: Electrical help please (should be easy)
96-98; All models, 99-00; D16Y5 (m/t): Blue wire from distributor.
99-00; All models except D16Y5 (m/t): A19 at the ECU (or tap the unused terminal of the ICM, which is where the Blue wire above is actually coming from).
Old Mar 12, 2010 | 09:26 AM
D16Z6 is my engine
92-95 I think
And yes it is manual
Is the signal wire 12v?
Old Mar 12, 2010 | 09:38 AM
EE_Chris's Avatar
For 92-95 Civic's, the Blue wire is it. Yes, it's a 12v signal.
Old Mar 12, 2010 | 09:50 AM
ok thank you ........
1 2 or 3 ???
Old Mar 12, 2010 | 09:57 AM
EE_Chris's Avatar
#3 - It'll be sharing the same connector that the Blk/Yel wire is in.
#1 (Blu/Grn) & #2 (Blu/Yel) are both for the Crank sensor.
Old Mar 12, 2010 | 10:01 AM
Dude * HIGH-FIVE
Thanks man. I'll try it out when i get home.
Kingpho
Apr 1, 2012 05:48 AM
jareddx
Mar 4, 2010 06:59 AM
97ek9
Honda Civic (2001 - 2005)
Jun 27, 2007 08:36 PM
Gonzo_SiR
Oct 29, 2003 10:12 PM
serious
Jan 22, 2003 11:21 PM
