Rc injectors, O ring not fitting??
Old Mar 27, 2010 | 04:34 PM
dc2_build's Avatar
Default Rc injectors, O ring not fitting??
ok i got some RC 310cc injectors yesterday. got them in the mail, had to insatall them asap ; )
when i tried putting them in my manifold they werent fitting. too big for the O rings. i pulled the O rings out of the manifold and squeezed them on the injectors but then neither went in the manifold. im using stock O rings from my gsr injectors. i shoulda knew it wasnt gonna work, so what do i do?
i know obviously i should hit up RC about using aftermarket o rings.. but is they any particular O ring i can run.. or is there a way to wide up my stock o rings.
im sure hella ppl have tried this so can someone help
Old Mar 27, 2010 | 07:13 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Rc injectors, O ring not fitting??
You have to use a dremel or die grinder to open up the hole in the o-ring...
I thought everyone knew this.
Old Mar 28, 2010 | 04:27 PM
dc2_build's Avatar
alright ill try that then..
Old Mar 29, 2010 | 03:29 AM
OH_1fstgsr's Avatar
Take a look at this. It's not suppose to be a perfect fit.
Old Mar 29, 2010 | 07:15 AM
dc2_build's Avatar
ahhh okay kool ill just do that then : ) i actually had it like that and thought " hey this shouldnt leak right : / well this time ill tighten the nuts until the injectors go into the seal somewhat and make sure all the pressure is even. and maybe ill take a pic and post it on here
Old Mar 29, 2010 | 07:27 AM
OH_1fstgsr's Avatar
My RC370 don't leak. These where installed in a GSR Manifold, no issues. Now they are in a a Performer X, still no issues. I just used new o-rings when I switched IM's.
Old Nov 9, 2014 | 10:50 PM
b16eh2's Avatar
By any chance do i guys know where i can buy new o rings? I just bought some as well but theyre all missing the seals,could i buy oem honda or i have to buy other ones?
JDM_Ej
Aug 8, 2005 12:32 PM
SupaFly_Honda
Jun 15, 2005 06:12 AM
hybridtuner
Aug 25, 2002 03:36 PM
dustin
Feb 10, 2002 09:49 PM
