NEED HELP i deleted cat n throw code
Old Mar 24, 2010 | 05:19 PM
Crazyxc2448's Avatar
Icon3 NEED HELP i deleted cat n throw code
i deleted my cat on my 2001 prelude and ithrow CEL and its the cat cat O2 sensor i want to know how to make it go away or how to delete it by tuning or something please help tired of running rich fuel
Old Mar 24, 2010 | 08:31 PM
EJ1civic coupe's Avatar
Default Re: NEED HELP i deleted cat n throw code
r u saying the o2 plugs into the cat? if so thats ur prob..of course its gonna throw a cel..put a cat back on it...
Old Mar 24, 2010 | 09:19 PM
mouab18c1's Avatar
If you run a chipped ecu you can cross off the o2 sensor. That is your only way to make you CEL disappear or take the bulb out.
Old Mar 25, 2010 | 02:52 AM
I had to cut the cat of my lude cus I blew the first motor up n we couldn't get the bolts to break loose from the downpipe so we cut the cat off n there was a O2 sensor in it when we welded a pipe in the place of the cat we plug the O2 back in n just zip tied it to the heatshield under the car n I have. Had a CEL since we swapped motors n I'm 99% sure its throwing the second O2 code on the car I want to know how to get it deleted so it will quit throwing it n would I have to switch to ODB1 too?
Old Mar 25, 2010 | 09:45 AM
mouab18c1's Avatar
Jump your ecu to see what exact code its throwing. And switching to obd1 is the only way to cross it off.
Old Mar 25, 2010 | 03:56 PM
So how do u go about to switching from obd2 to obd1 then
yee SERIOUS
Sep 14, 2005 07:17 PM
2k1 SSM GSR
Oct 22, 2004 11:30 AM
Two_K Si
Oct 13, 2004 08:32 PM
piotrush
Feb 9, 2004 09:51 PM
