S40 Shift Forks on a S20 ???
Old Mar 28, 2010 | 05:06 PM
Boosted_01 R's Avatar
Default S40 Shift Forks on a S20 ???
Well had problems with my last S20 tranny and never got it figured it out, so am replacing it with another S20.......I been reading that the S20 have AL shift forks, and the S40 have steel....... I originally pulled a S40 from my car, was wondering:
If i could swap my S40 shifter forks into my S20 or would they not work with the sliders?
Any help would be great
Thanks
Old Mar 29, 2010 | 05:18 PM
94EG8's Avatar
Seagull Management
Default Re: S40 Shift Forks on a S20 ???
S40 forks wont work in an S20 case and vice versa. You can use the S40 forks with the S40 case and use S20 parts for the rest of the tranny though. Personally I like the S20 forks better, S40 in my expirence seem to have wear issues with the 3rd/4th shift fork. If you look at the forks you'll see that the aluminum forks are designed to be quite strong, they are reinforced in a way the steel ones aren't.
Old Apr 1, 2010 | 02:23 AM
Thanks for the info..................anything from the S40 worth using in the S20?
patiencecali
Aug 26, 2012 07:18 PM
mmmbrapND
Transmission & Drivetrain
Apr 7, 2009 06:18 PM
kabaroo
11
Apr 1, 2005 12:12 PM
snatch
12
Jul 16, 2004 03:42 PM
VtecDA9
Aug 4, 2003 06:33 AM
