Transmisoin soft line
Old Mar 24, 2010 | 09:28 PM
The-obd0-one's Avatar
Default Transmisoin soft line
Me and my buddy are doing an itr swap on his 93 eg hatch and we need a new soft line for hydralic clutch the problem is that the the fiting on the hard line will not screw into the soft line it's to big it's vise versa for the line that came on the car my qetion is were can I git a soft line with two diffrent sized female fittings at each end to adapt it
Old Apr 21, 2010 | 10:33 AM
Default Re: Transmisoin soft line
bump
Old May 2, 2010 | 08:22 PM
Old May 2, 2010 | 08:32 PM
95DC2GS-R's Avatar
you can get the fittings and line online and make it, or i'm sure there's a hydraulic shop near you, give them the old hose and tell them to make the same one and they can usually do it right there on the spot in a lot of different hoses
Old May 2, 2010 | 09:14 PM
eflove's Avatar
I had a issue like this in my JDM integra. I needed a soft line with both fittings the same size (small). I got a 98 soft line went to bolt it up and only one side would fit the other was too big. Sounds like you need that line. Try a 98 integra line.
Old May 3, 2010 | 10:05 AM
what type of too do you use to press the fitting onto the hose and were can i git the fittings like a dealership or something
Old May 4, 2010 | 09:21 AM
T.Sewell's Avatar
most places that sell fittings of this sort should have them, if not just go to dealership or order online
Old May 4, 2010 | 10:09 AM
alright thanks
HamiltonRex
Apr 17, 2006 05:17 PM
flat-blk-HB
Apr 28, 2003 04:50 PM
jthelman
Sep 11, 2002 01:49 AM
