BUILT MOTOR NOT SEALING PROPERLY
Old Mar 29, 2010 | 05:51 PM
ysofasts2k's Avatar
Default BUILT MOTOR NOT SEALING PROPERLY
okay evening fellas, i have a built motor golden eagle sleeves o-ringed and etc, problem im having is that when i fill the cylinder with air to make sure the motor is sealing properly i end up pushing air through the radiator, so i figure the headgasket isnt sealing to the block properly or maybe the head is messed up or maybe the headgasket just sucks, either way here are the specs
golden eagle 85 mm b18b with o rings
gsr head
both the head and block have been decked and cut,
cometic 85 mm and copper headgasket 85 mm
both headgastkets i have tried and the motor wont seem to seal properly
Old Mar 29, 2010 | 08:18 PM
98integralsB18's Avatar
Default Re: BUILT MOTOR NOT SEALING PROPERLY
is the head warped? did you get the head decked or anything like that?
Old Mar 29, 2010 | 08:23 PM
ysofasts2k's Avatar
head and block was deck aand cut, im really leaning towards the head being bad but im not sure cuz everything checks out
Old Mar 29, 2010 | 08:52 PM
Scott_Tucker's Avatar
Did you have the head pressure checked?
Old Mar 29, 2010 | 08:58 PM
ysofasts2k's Avatar
the head was checked dont think they pressure tested it, thats why i torque the head down then fill the cylinder with air to ensure proper seal and i end up seeing water start bubbling from the radiator and ****
Old Mar 30, 2010 | 09:03 AM
clutchrsx's Avatar
its recommended to be using the copper headgaskets with oring'ed blocks. what are u torquing the head down to? reputable shop do the oringing? it's either your orings or the headgasket not sealing properly
Old Mar 30, 2010 | 09:13 AM
ysofasts2k's Avatar
well i have an 85mm copper gasket and also a cometic gasket and i have problems with both
justYncredible
Apr 16, 2016 08:54 PM
ysofasts2k
Mar 30, 2010 06:36 AM
xxtavixx
Classic Hondas
May 9, 2009 09:05 PM
7rrivera7
Aug 4, 2006 09:25 AM
kamira
Jun 30, 2002 01:17 PM
