fuel line ?
Old Mar 22, 2010 | 09:14 PM
2point1's Avatar
Default fuel line ?
need help with fuel line location, i want to move the fuel feed line from the passengers side to the drivers side of the fuel rail. can this be done with out any problems? im using an aem rail and regulator.i have search this and found nothing. this is how i would like to set up the feed and return lines..thanks for the help
Old Mar 23, 2010 | 10:19 AM
2point1's Avatar
Default Re: fuel line ?
any one ????????????
Old Mar 23, 2010 | 01:47 PM
2point1's Avatar
47 Views and no help?????
Old Mar 23, 2010 | 02:12 PM
nsxter's Avatar
yes you can what cant you figure out it is very easy
Old Mar 23, 2010 | 02:55 PM
2point1's Avatar
i wanted to make sure im not going to have pressure drop
Old Mar 23, 2010 | 03:01 PM
fourthgenhatchB17's Avatar
You'll be fine. Your return will then be on the passenger side right? Why the switch?
Old Mar 23, 2010 | 03:26 PM
2point1's Avatar
nope both the feed and return will be on the same side. i want to keep the bay clean
Old Mar 23, 2010 | 07:11 PM
Gotcha.
Old Mar 24, 2010 | 06:23 AM
Mikey3000's Avatar
how the hell can you have feed and return on the same side of the fuel rail? they need to be on opposite sides so the fuel that isn't used by the injectors can be returned to the tank!
Old Mar 24, 2010 | 06:34 AM
em_at_kfi's Avatar
You could mount the pr valve right after the pump under the car if you wanted.
Flow through the inlets up to the rail, return back to the tank.
It's a closed, pressurized circuit. You can put the relief point anywhere.
The only disadvantage to plumbing it like that is: any air bubbles in the system will be forced out through an injector instead of looping around and returning back to the tank.
Since pictures speak 1000 words:
Sorry - mom wouldn't pay for art school. lol
Old Mar 24, 2010 | 06:53 AM
em_at_kfi's Avatar
Just a FYI: the lower schematic I drew is exactly how many OEM's plumb cars now, except the pump and pr valve would actually be inside the tank.
Old Mar 24, 2010 | 10:57 AM
2point1's Avatar
this is how i would like to set it up..
Old Mar 24, 2010 | 11:03 AM
em_at_kfi's Avatar
That will be just fine.
Old Mar 24, 2010 | 02:16 PM
2point1's Avatar
thanks,any one else?
dodger
Dec 8, 2011 03:10 AM
grkblood13
Mar 30, 2009 02:42 PM
elite01
Honda Civic (2001 - 2005)
Sep 27, 2007 11:35 AM
DJaeMac
Sep 26, 2007 08:57 PM
Salvatiosix
Feb 21, 2004 08:41 AM
