94 Civic automatic harness, convert to manual?
Old Mar 13, 2010 | 08:56 AM
thumper64's Avatar
Default 94 Civic automatic harness, convert to manual?
I have a 1994 Civic EX and it seems a shame to throw the harness away, so I want to convert it. I think I have an idea what I need to do, I'm just making sure.
The IACV needs to be rewired.
A switch for the reverse light for the transmission has to be added.
Other than that, a knock sensor and IAB wiring is optional.
Is there anything else?
Old Mar 13, 2010 | 02:21 PM
94EG8's Avatar
Seagull Management
Default Re: 94 Civic automatic harness, convert to manual?
Its identical to the 5 speed harness. Its the cabin harness that differs in '92 - '95 Civics. Check honda for yourself if you don't believe me, part numbers are identical. All OBD1 civics used a two wire IACV btw, and the backup light wiring is used for the automatic transmission solenoids, same plug, wire colors and pinouts though, hence the harnesses being the same.
Old Mar 13, 2010 | 09:36 PM
TurboTeG4's Avatar
I converted a 94 civic dx coupe from auto to standard a long time ago, I dont remember changing anything electronical but the ecu.
Old Mar 15, 2010 | 08:35 PM
thumper64's Avatar
I'll be danged. Well, thanks for the help.
Old Jul 18, 2010 | 01:09 AM
eric76's Avatar
i also did tuning on my civic a while back. had it converted to standard. this time i am planning to get a bit more power in it by adding a turbo. i hope i would be able to maintain my 94 civic with almost the same budget as previously.planning to get a paint job on it too. would be posting the pics soon.
eebaker
Nov 19, 2017 04:47 AM
allanjr350
10
Jul 2, 2015 08:26 PM
civic-steve-94
11
Oct 31, 2011 06:51 PM
vtechjunkie
Jul 7, 2009 06:01 AM
VRD^suzie
Jun 30, 2008 08:42 AM
