single cam crank specs.
Old Mar 19, 2010 | 10:44 AM
weggies4life's Avatar
Default single cam crank specs.
I have a d15 b7 with a crank with a piece broke off by the keyway and i went to the junkyard and the crank was broke just like mine.
i was wondering why they are both broke asin what could cause it to break and is there another crank i can use to match journal sizes to girdle and rods for my block.
thanks Nick
Old Mar 19, 2010 | 05:31 PM
Blaze45's Avatar
Brrraaaap!
Default Re: single cam crank specs.
Why not just pick up one for sale in the classifieds? I am sure that they can be had cheap if you look hard enough. I would research and see if you can run any other D series pulley. You could also look at this as an opportunity to upgrade to a nice fluidamper unit.
Old Mar 21, 2010 | 06:35 PM
zedron's Avatar
Since you live local in the Tampa area, ask in the "Honda/Acura Classifieds" section on Tamparacing.com
There are a bunch of people selling things on there and you can pick it all up.
Old Apr 1, 2010 | 10:27 PM
nobody has anything and the people that say they have a crank always just dick me around and i need someone straight up
Old Apr 2, 2010 | 05:11 PM
clutchrsx's Avatar
if u replace your crank with another, be sure u measure bearing clearances for mains and rods
weggies4life
Apr 1, 2010 10:15 PM
ls19integra95
Apr 1, 2007 11:42 AM
A-busive
Aug 1, 2006 10:49 PM
egcivic123
Jan 15, 2005 12:38 PM
TheSwift1
May 29, 2002 10:42 AM
