HELP QUICK
Old Mar 20, 2002 | 12:24 PM
Speed PHreak's Avatar
Default HELP QUICK
Ok I've gotten all my 680cc 84-85 RX7 injectors together and I was in the process of cleaning them up and found a hairline crack down the nylon casing around the pintle on one of them. Can I still use this injector?
Old Mar 20, 2002 | 12:44 PM
hybridreams's Avatar
Default Re: HELP QUICK (Speed PHreak)
I would toss 'em. Even if they work fine now, why wait for it to become a problem? Fix what you can while you can IMO.
Old Mar 20, 2002 | 12:47 PM
Kalokohan's Avatar
New User
Yep, if you use it, it could cause a much bigger problem. Nip it in the bud.
Old Mar 20, 2002 | 02:46 PM
Default Re: HELP QUICK (Guardson3r3)
hmm, intesting. I'm gonna test the injector to see if it will hold rail pressure, if all goes well i'll take it out on a run and then check the plugs
slideintegra08
Jun 5, 2012 01:45 PM
civ_nate
May 19, 2007 09:09 AM
Mikey3000
Apr 1, 2006 03:36 PM
FOrSfEd
Jun 21, 2002 04:59 AM
