APR head studs question!!!!
Old Mar 23, 2002 | 04:31 PM
SCsol's Avatar
Default APR head studs question!!!!
i heard that you have to torque the head studs 3 times when the studs are new to pre streach them is this true and also what did you use to put the studs into the block? What is the best way please post !! thanks guys going to install them tonight the motor is GSR and what did you torque the studs to
Old Mar 23, 2002 | 04:42 PM
non-VTEC's Avatar
Default Re: APR head studs question!!!! (lowsol)
sorry i dont know the answer to your question but i was wondering how much the set of ARP headstuds cost you?
well maybe i can give you an anwser.........ARP usually supplies instructions with their products........follow their instructions and you should be fine.
Old Mar 23, 2002 | 04:43 PM
rainforest's Avatar
Default Re: APR head studs question!!!! (non-VTEC)
yeah you hand tighten them then go through 3 stages. of 90 degree turns.
Old Mar 23, 2002 | 06:39 PM
builthatch's Avatar
MiG-21 superfan
dip them in clean oil or use the supplied lube. then go about the sequence in three steps. 15-20 35-45 then tork to max spec . remember to compensate for the extension, i go 4 ft lb over spec.
tico
10
Feb 25, 2013 08:33 PM
hey man
Apr 18, 2010 04:21 PM
Project_EK
Jul 13, 2008 07:19 PM
Jap_Spec_Imports
Nov 1, 2007 06:15 PM
BlueTeg
16
Feb 4, 2007 11:47 AM
