Need HeLP with RadiatoR fans
^^Need HeLP with RadiatoR fans^^
I have a 94 integra and I replaced my radiator & fans when I rear ended another car. Well, the ones I have on now aren't working, I mean the fans. I know for a fact that they don't turn on. I never heard or seen them go on. I've even popped the hood and left the car running to see if it will turn on and it never did. I need anybody's help, pls. What should I do?
As of right now, my car doesn't over heat even when I street race. But I think that's because of the cold weather. Summer is comming soon and I want this fixed asap.
Also I don' want to buy a FAL, too expensive.
I'm thinking maybe this could be fixed. Hopefully.
Any comment, help, or feedback welcomed.
Thanks in advance.
Thanks in advance.
sometimes the fan plugs get gunked upand wont get a good connection try checking the plugs and cleaning them up or like 94hondahybrid said toggle switch!!thats what i had to do after my swap...fans wont come on so i just ran wires for a toggle and now i know they are working when i need them too..
also did you check your fuses for your fans they could have blew too
The wires and all the connnection look clean.
and that hardwiring stuff.......i don't even know where to start
i need HelP
thankx for the responses
i need HelP
Before you test if the fans work check your fuses and relays.
To check a relay/fuse unplug the fan connector and run the car till the fans should be on. then put a voltmeter on the connector coming from the car if it shows 12 or in that area then the relay/fuse(s) are good.
try testing to make sure the fans work by unplugging the fan from the connector and putting wire into the respective + and - on the connector. Run the - to a metal body part and the positive to the battery to make sure the fan turns on. If it doesn't or spins very slowly then the motor is fried and probably took out the fuse and relay with it.
Isn't one of the fans just for when the A/C is running?
n yeah one more info i forgot to add
I replaced my radiator with one from 2000GSR
Would that have caused the problem in any way?
bigchris2000
14
Aug 6, 2010 08:25 PM
