Limp mode, need help!
Old Mar 26, 2002 | 11:28 AM
drifter's Avatar
Default Limp mode, need help!
Well i wanted to see if i could keep the secondary butterflies open if i took off the vacuum hose off of the diaphram. Well the car ran like *****. But know i can't get it out of limp mode. if the car is cold and i start it and quickly put the hose on the car will run great for about 45 seconds then start running real weak again. How can i fix this!!! The car is a GSR. Any help would be GREATLY appreciated.
Old Mar 26, 2002 | 12:05 PM
Omega_GSR's Avatar
Default Re: Limp mode, need help! (drifter)
When you start up the car the vacuum actuates the diaphragm and CLOSES the butterfly (when the car is off the butterflies are actually open).
So having taken off the vacuum line, the butterfly remains open and the engine is getting the same volume of air as it would at 5800+rpm when it is supposed to open.
If you notice underneath your intake manifold there is a little black canister with some vacuum lines and a couple of wires coming out of it. That is what dumps the vacuum and opens the secondaries at 5800 rpm I think it is called the IAB valve or something like that.
As for your limp mode put everything back the way it was and disconnect your battery for 10 minutes, reconnect it and that should reset your computer and if everything is connected properly your car will be happy again.
Hope this helps!
Old Mar 26, 2002 | 03:18 PM
drifter's Avatar
Default Re: Limp mode, need help! (Omega_GSR)
well everything is connected and i took off the negative battery cable for like 20 minutes and then drove the car and it still ran like **** I'm getting very frustrated.
Old Mar 26, 2002 | 04:12 PM
CivicEK.PDX's Avatar
pull the backup fuse for 10 seconds.
Old Mar 26, 2002 | 05:25 PM
drifter's Avatar
Default Re: Limp mode, need help! (CivicEK.PDX)
That did the trick. You are a godsend pdx thanks a ton. I owe you a six pack no wait make that a keg My car finally feels drivable
Old Mar 26, 2002 | 05:28 PM
fixhondas's Avatar
removing the battery terminal is the same as pulling the fuse
Old Mar 27, 2002 | 02:48 AM
EE_Chris's Avatar
Default Re: Limp mode, need help! (fixhondas)
Yeah for real...pulling the (-) battery terminal resets everything. People will tell you to pull that 7.5A Hazard Fuse so that you DON'T reset your radio stations, but at the same time this action will reset your ECU. So either method works like a charm.
Old Mar 27, 2002 | 03:01 AM
Default Re: Limp mode, need help! (EE_Chris)
ya....but the backup fuse will reset the ECU and radio 100%. Also if you make it a hait to use the battery cable (-) then you make get sick of unbolting the the terminal and just let it sit loose.
tgkaotic
Oct 3, 2012 09:21 PM
touandcim
Jul 13, 2007 01:09 PM
InvaderTrax
May 20, 2007 12:32 PM
Sporno
Feb 18, 2006 04:39 AM
93H22A
Dec 25, 2001 11:23 PM
