PCV Valve necessary???????
Old Mar 22, 2002 | 09:10 PM
BpuTacoma's Avatar
Default PCV Valve necessary???????
i have a d15b2 and a b18a1 and both of them the pcv valve is not connected because it broke both times and i just left the big hole in the thing under the intake manifold. is this ok or is it gonna cause some probs in the future. thanks.
Old Mar 22, 2002 | 09:59 PM
nakashima79's Avatar
Default Re: PCV Valve necessary??????? (BpuTacoma)
you need PCV valves,,. It doesn't rob your power at all. And if you left big hole on valve cover, engine oil gonna leak crazy. I suggest you to get new one it only cost you around$5. hope this helps.
Old Mar 22, 2002 | 10:00 PM
gogu's Avatar
yes you do need it its a positive crankcase ventilation valve that helps the engine clear out blowby gases
mclasser
Mar 26, 2013 04:06 AM
kb58
Mar 24, 2011 10:38 AM
Jimhvis
Mar 25, 2009 05:53 PM
petrv
Aug 26, 2005 02:26 PM
dr juice164
Jul 11, 2004 10:04 AM
