--HAVING A IDLE PROBLEM--HELPPPPPP!!!!!!!!!!!!!!!!!!!
Old Mar 22, 2002 | 06:04 AM
b16vteccx's Avatar
Default --HAVING A IDLE PROBLEM--HELPPPPPP!!!!!!!!!!!!!!!!!!!
OK here it is, when i start the car up (cold) it idles normal like 1300-1500 but the engine JUMPS UP AND DOWN, as it gets warmer and the idle drops it slows down the shaking but doesnt stop it, now that its fully warm the idle usually surged from 900 -1300 or so because the 02 is not wired yet, but now after headgasket replacement, the car surges down to about 400 (almost shuttin off) but it wont die, it will idle like that forever surging uppppp and downnnnn?????????????
any help please!!!!
Old Mar 22, 2002 | 06:10 AM
Kamin's Avatar
Default Re: --HAVING A IDLE PROBLEM--HELPPPPPP!!!!!!!!!!!!!!!!!!! (b16vteccx)
the o2 sensor has nothing to do with it
take your IACV off and clean the little screen. (should be on the bottom of the intake manifold)
Old Mar 22, 2002 | 06:16 AM
rainforest's Avatar
Default Re: --HAVING A IDLE PROBLEM--HELPPPPPP!!!!!!!!!!!!!!!!!!! (KAMiN)
either eacv or fast idel valve(cold start valve) the eacv is trying to keep the idel at normal speeds while the car is cold but if the cold start valve doent open the eacv will want to compensate for the vacume loss.pwn3d
TearSDMF89dx
Jan 3, 2012 04:31 AM
Junkyard2000
Sep 14, 2005 07:07 PM
devonic
Sep 26, 2003 08:55 AM
s2k
Feb 25, 2003 06:50 PM
wickedxboi
Nov 9, 2002 12:39 PM
