LSVTEC, knock sensor, and a CEL.
Old Mar 20, 2002 | 04:34 AM
93B18's Avatar
Default LSVTEC, knock sensor, and a CEL.
I just finished dropping in my freshly built LSVTEC. Now I don't have the knock sensor hooked up on the block and I'm getting a CEL for it. Is there anyway to disable the knock sensor without rechipping my ECU? BTW, I'm running a P61 92-93 GSR ECU. TIA for the info.
Old Mar 20, 2002 | 04:54 AM
Sleeper's Avatar
Default Re: LSVTEC, knock sensor, and a CEL. (93B18)
You could hook up the sensor and zip tie it to something to get rid of the CEL. Or there should be a plug on the LS block where the knock sensor goes(same spot as vtec block). Remove said plug and install sensor. I'll pm you a pic.
Old Mar 20, 2002 | 06:02 AM
93B18's Avatar
Default Re: LSVTEC, knock sensor, and a CEL. (Sleeper)
Thanks for the reply. You have mail.
Old Mar 20, 2002 | 08:26 AM
b18bvtec4drteg's Avatar
I never seen a plug on my b18b.. want to pm me the pic also?? I just took out the bulb on the dash..
Old Mar 20, 2002 | 09:26 AM
crxfactor1991's Avatar
Default Re: LSVTEC, knock sensor, and a CEL. (b18bvtec4drteg)
there wasnt a plug on my 93 ls block, so i had to drill and tap a hole for it
if you took the CEL bulb out, how are you going to know if you have future problems?
Old Mar 20, 2002 | 10:03 AM
3rdGteg's Avatar
Default Re: LSVTEC, knock sensor, and a CEL. (crxfactor1991)
You can always wire it up and wrap it with a towel and just place it somewhere but it's not going to do it's job; I heard it's supposed to detect detonation or something like that--anybody knows?
petarr
Mar 4, 2006 10:37 AM
BlueShadow
Jul 20, 2005 12:24 PM
93si-hybrid
Jul 15, 2004 01:09 PM
Thagreybomber
Sep 11, 2002 10:16 PM
MrFatBooty
Dec 12, 2001 10:11 AM
