Can't shift into third gear! help!
Old Mar 20, 2002 | 05:02 PM
MeanGreenEG9's Avatar
Default Can't shift into third gear! help!
I have a 96 civic ex and my third gear grinded for the longest time and just got worse and worse but now I can't even shift it into third at all! my second grinds a bit now but not that bad.. i thought if i double clutched it would go in but it STILL doesn't!! tranny's got 80k miles on it but it actually started grinding around 40k.. do I need a new tranny? Anyone else have this problem? it sucks!!!
Old Mar 20, 2002 | 05:36 PM
Kataku2K3's Avatar
Default Re: Can't shift into third gear! help! (EKb18b)
Get a new one or rebuild your existing one. My guess is that the syncros are really really fucked!!!!
[Modified by JDMspecEG6, 2:37 AM 3/21/2002]
Old Mar 20, 2002 | 09:43 PM
nakashima79's Avatar
make sure you have enough tranny lubricant in your trans. If it still grinds, I would check clutch system make sure it doesn't have air in system. If it has air, clutch doesn't disengage all the way or not at all. If you check these thing and found no problem, maybe your shift linkage adjustment is out or your tranny needs to be overhauled or replaced. I hope this helps,, thanks
teggy_617
May 14, 2009 05:21 PM
NOOdS
Apr 20, 2009 11:04 AM
boosted_EM1
12
Feb 7, 2008 12:58 PM
Skinnypunk
May 30, 2004 10:41 AM
boomslang
Nov 18, 2001 12:00 AM
