b20 pistons
Old Mar 20, 2002 | 03:37 AM
sleepercivic143's Avatar
Default b20 pistons
i am about to build a b20 vtec. i am choosing between the ITR head and the b16 head. which one will do better? and also, what pistons can i use for the b20 block>? can i use the ITR pistons for lightweight purposes? can i also use the venturi plate by spoon to increase the flow of fuel in the cylinder?
Old Mar 20, 2002 | 05:28 AM
Sleeper's Avatar
Default Re: b20 pistons (sleepercivic143)
Do some more research dude. ITR is a ported B16A head, with better valvetrain components. B20 has a bigger bore(84mm), so you can't use ITR pistons(81mm). You need aftermarket pistons, or cut larger valve reliefs in the stockers to avoid piston to valve contact with a vtec head. Fuel delivery(flow) is controlled by injector size, pressure, pulse width, and duration. Not plates.
Old Mar 20, 2002 | 09:53 AM
Kataku2K3's Avatar
Default Re: b20 pistons (Sleeper)
I would just port out the B16 head it's probably cheaper. Then get an ITR intake manifold. As for pistons i would definately recommend using ENDYN Rollerwaves. Build a setup like HX_guy, his 97 coupe runs high 12's all motor.
Old Mar 20, 2002 | 03:21 PM
Default Re: b20 pistons (JDMspecEG6)
wht is the set up of HX_guy?
Old Mar 28, 2002 | 08:25 AM
Kataku2K3's Avatar
Sorry i took so long to get back. I had to find some **** where he posted what he has. He says he's selling his setup because he's gonna get a Acura CL. Oh well here's the ****.
(Im thinking of selling my setup. What would be a fair price to ask.
2000 CRV B20Z2 block
1999 SI B16A2 head
Endyn 84.5mm pistons (11.94:1 CR)
Eagle rods
GSR crank girdle/windage tray/oil pickupoil pan
All new bearings and seals
1997 Spec ITR cams
Portflow retainers
Portflow inner valve springs
ITR outer valve springs
ITR intake manifold
JG 64mm Throttle body
Ported JDM ITR 4-1 header
B&M fuel pressure regulator
Walbro 255 LPH fuel pump
Stock 240cc injectors
Chipped P28 ECU w/Mugen chip
VAFC (tuned for setup)
96-98 OBDII - OBDI ecu harness
GSR transmission
Clutchmasters 7.5 LB flywheel
ACT Street/Strip clutch
Axles and mounts
The engine dyno'd at 208 WHP / 154 TQ and ran 12.91 @ 106.98 MPH on drag radials in a 2450 w/driver Civic.) HX_Guy
GSi-R
Mar 22, 2009 04:32 AM
kenney
Nov 23, 2008 04:24 PM
Mr.E.G.
Oct 1, 2004 08:09 AM
