something about a camber kit and an alignment...
Old Mar 23, 2002 | 08:09 AM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default something about a camber kit and an alignment...
i bought f&r ingall's camber kit because my car was too low and i thought you have to get an aligment when you put this sheiiit on right? put the camber kit on and took it to several places to get my aligment and all the places told me that they can't align my car because it is lowered and that it won't spec to what it is supposed to...so is there a special place to get this done or am i going to have to sell these expensive little things and raise my car up some?
Old Mar 23, 2002 | 04:48 PM
rainforest's Avatar
Default Re: something about a camber kit and an alignment... (not so civic)
you should call the company that makes the springs and they should be able to tell you the spec then you tell them what the specs are and then get it allined
Old Dec 31, 2002 | 04:46 AM
Fuster_Cluck's Avatar
Hey Kevin, I don't know if you ever found a shop to do the alignment or not, but I used Savannah Tire when my 98 LX was dumped about 2.5 - 2.75" on Ground Controls. I actually got to watch the entire process and it was a breeze to adjust the skunk2 kit and toe. The rear was shimmed out with washers and longer bolts so the guy just adjusted the toe to 0.
It only took a few minutes to do the entire wheels.
PS <> I found this thread because I was searching through threads you posted looking for pics / specs of the motor & turbo Later!
Old Dec 31, 2002 | 05:59 PM
Default Re: something about a camber kit and an alignment... (Hybrid93Hatch)
hey man what's up? i just happen to be looking around where i don't normally and i see this thread! this thing is pretty damn old. i still haven't got an alignment but just got some new dunlops so i'll be sure to and now i know where to go. i also found that smitty's frame shop also does lowered alignments. if you want pictures of my set up then gimme yo e-mail. mine's b18bhybrid@hotmail.com if you ever need it. hasta.
FLACO EM1
Nov 27, 2008 01:39 PM
kasperxtcy
Suspension & Brakes
Nov 6, 2007 10:19 AM
imonx850
Suspension & Brakes
Mar 14, 2005 08:47 AM
AzntaggeR
Feb 27, 2003 05:59 PM
631 Teggy
Jan 18, 2003 07:38 AM
