GSR in a Del Sol
Old Mar 19, 2002 | 10:26 PM
94gsrsol's Avatar
Default GSR in a Del Sol
I have heard that I need a del sol vtec shift linkage, is this true? Anything else I need to look out for?
Old Mar 21, 2002 | 09:10 AM
bojangs's Avatar
New User
Default Re: GSR in a Del Sol (94gsrsol)
edited..
yes, you do need to get a del sol vtec linkage.. they're WAY different then gsr/ls/si linkages.. you could always get one of these three linkages and have the ends welded on your stock shift linkage
[Modified by bojangs, 6:55 PM 3/21/2002]
Old Mar 21, 2002 | 10:25 AM
salbaje's Avatar
yes you need the delsol dohc vtec shiftlinkage. they have different curves as the gsr/si linkages. they are like 170 at dealers
Old Mar 21, 2002 | 01:07 PM
94gsrsol's Avatar
Default Re: GSR in a Del Sol (salbaje)
Man, I am thinking about hacking one of the many linkages I have. Is the gsr one too long or too short what. I want one I would have to add a lil bit onto because I don't want to cut to much off you know. Any info on this or should I just spend the dough?
Old Mar 21, 2002 | 03:13 PM
riceboy's Avatar
Cut and weld the GSR linkage, but have a reputable shop do it for you, the only reason I say to cut and weld is for the ability to use the GSR shifter with out having to size it to fit, plus a buddy of mine did this swap several years back, thats how he did it, so I know it works.
bo98teg
Jul 7, 2010 03:20 PM
07jdmfit
May 27, 2009 07:36 PM
spunky424
Aug 15, 2006 08:25 AM
AzntaggeR
Dec 23, 2003 09:34 PM
94si94cx
Jul 2, 2003 08:53 AM
