idle problem
Old Mar 20, 2002 | 07:35 PM
oem's Avatar
oem
Default idle problem
Hi have a 97 Dx coupe, just completed my swap B16A2, everything is good except the idle.
When i start the car it idles 1500-2000 rpm. And it doesn't drop to 900rpm until 5-10 mins later or until the car is warmed up. it's been doing this for about 2 weeks. Any help is appreciated thx.
Old Mar 20, 2002 | 07:57 PM
StyleTEG's Avatar
Default Re: idle problem (utboi)
This is normal.
Old Mar 20, 2002 | 07:59 PM
rainforest's Avatar
Default Re: idle problem (StyleTEG)
nope check the eacv screen and all vacume lines.
Old Mar 20, 2002 | 08:11 PM
Ri5e's Avatar
Default Re: idle problem (rainforest)
That's what my car does. Idles at 1600 RPMS when it first starts up cold. Then drops down to 750 +- 50 when its warm, which is like 5 mins in cold weather.
Old Mar 20, 2002 | 08:48 PM
89 CRX SI's Avatar
Default Re: idle problem (BG Boost)
Yeah thats what they do cause its auto choke instead of a 5th injector like VW or Mazdas startup system
Old Mar 21, 2002 | 09:45 AM
oem's Avatar
oem
how is this normal guys? My car idles like crap.....isn't my car suppose to idle at 900 as soon as i turn the crank?
Old Mar 21, 2002 | 10:18 AM
StyleTEG's Avatar
It idles higher when the car is cold in order to aid in warming up the engine
Old Mar 21, 2002 | 10:52 AM
Kamin's Avatar
yes when the car is cold it idles at 1500 untill it warms up then it is supposed to idle at 750 +-50.
just to be on the safe side check your IACV (idle air control valve) and vacume lines.
Old Mar 21, 2002 | 04:38 PM
TalonT's Avatar
New User
Default Re: idle problem (KAMiN)
Water Temp Sensor functioning within tolerance?
Apple395
Aug 16, 2013 10:13 PM
byronl
Jun 14, 2006 08:26 PM
Successor
Apr 30, 2003 04:04 PM
crashtest Sonny
13
Mar 4, 2003 03:49 PM
