Dialing out Overlap on Cams
Old Mar 25, 2002 | 06:25 PM
It's Blue's Avatar
New User
Default Dialing out Overlap on Cams
How do I do this??? I need to dial out the overlap or as much as I can because I am using the NOS kit. Do I need to retard the exhaust and advance the intake? Advance the exhaust and retard the intake? Or is it the total opposite like retard both intake and exhaust or advancing both??? I need help soon guys, the races start this Saturday and I have the last appointment at the dyno on Friday. I am running a 125 shot on the NOS kit # 02040 and on the dyno I am only gaining 73 hp. I think that I am losing the other 50hp thru blow-by, because of both intake and exhaust valves being open at the same time.
Old Mar 25, 2002 | 10:03 PM
b19coupe's Avatar
Default Re: Dialing out Overlap on Cams (It's Blue)
Overlap is when the exhaust valve is closing at the end of the exhaust stroke and the intake is opening at the beginning of the intake stroke. Four strokes in order are intake-compression-power-exhaust. If you advance the exhaust cam you will reduce overlap because the exhaust valves will close sooner.You can also reduce overlap by retarding the intake cam so that the intake valves will open later. Be careful not to go too far. I would'nt go more than a couple of degrees on either cam.
Old Mar 25, 2002 | 10:25 PM
rainforest's Avatar
Default Re: Dialing out Overlap on Cams (b19coupe)
true b19 but there are different set-ups. i have seen the total opposite when tuning on a dyno. so basiclly get camgears and take it to the dyno.
Old Mar 25, 2002 | 10:48 PM
b19coupe's Avatar
Default Re: Dialing out Overlap on Cams (rainforest)
I agree 100 percent. I was just answering the question. He may find more power with more overlap. Dynoing is the only way to know for sure.
Old Mar 26, 2002 | 06:05 AM
It's Blue's Avatar
New User
I agrre with you guys but the problem is that I pulled a 245 hp to the ground. Up only 70hp from baseline without NOS and I had it jetted for a 125 hp shot. So I am thinking that I am losing the other 50 thru blow-by.Need to slove it or at least get an idea on what to do before this Friday . Got another dyno appointment before the races on Saturday.
Old Mar 26, 2002 | 07:04 AM
John's Avatar
New User
Do you have a fuel pump to deliver the needed fuel for that large of a shot?
SoFresh1189
Feb 20, 2010 10:07 AM
It's Blue
Mar 26, 2002 04:20 PM
It's Blue
Mar 26, 2002 09:35 AM
It's Blue
Mar 26, 2002 06:01 AM
