ITR head on b16a?
Old Mar 24, 2002 | 06:46 PM
Timmayeg's Avatar
New User
Default ITR head on b16a?
just curious if a ITR head will work on a b16a? if so what modifications will i have to do?
is this worth it or should i just put the ITR internals in the b16a with the stock head?
Old Mar 24, 2002 | 06:59 PM
qtiger's Avatar
Default Re: ITR head on b16a? (B16aVtecCivic)
Not worth it, IMHO. If you are going to upgrade you might as well go over ITR specs.
Old Mar 24, 2002 | 10:54 PM
ToneyTigre's Avatar
New User
Default Re: ITR head on b16a? (qtiger)
yes it will fit. no mods. it is the exact same head except the ITR is mildly port polished. CTR=ITR=B16A + port polish.
[Modified by ToneyTigre, 11:55 PM 3/24/2002]
Old Mar 24, 2002 | 11:15 PM
Timmayeg's Avatar
New User
so the ITR head will make more power than itr internals i in the b16?
Old Mar 25, 2002 | 12:32 AM
Katman's Avatar
are you talking about block or head internals?
if head internals...
yes it will make more power than a stock b16a head. The power mainly coming from the camshafts, light port job, and R manifold. The R valvesprings and lightened intake valves help relieve some dead weight lingering in the valvetrain and actually allows about 200rpm more of higher reving.
if block internals are what you speak of...
1) putting a Type-R or any 1.8L crank in a b16a block is dumb. You'll have awful rod ratio on top of $$ you'll be wasting to get that damn thing to fit the 1.6 block.
2) you'll have to pay $$ to get custom rods made to work with the ITR crank in the 1.6 block.
3) you'll have better compression with the stock B16A pistons vs. the R pistons....unless you go CIVIC-R pistons.
Old Mar 25, 2002 | 05:39 AM
Westrock2000's Avatar
Default Re: ITR head on b16a? (Katman)
I don't know....the B18C5 head has bigger ports and stuff because the rod ratio of the block can use it at lower engine speed. The B16 just breathes differently. Id say just upgrade the valvetrain if you want bigger cams and whatnot, I mean you could get that baby spinning faster than a B18C5.
Eddygee53
16
Jul 9, 2019 12:19 PM
cacahead1
Aug 14, 2005 08:31 PM
2ndgent3g
16
Nov 24, 2004 05:41 AM
Jaysmy
Jun 27, 2002 05:13 PM
2fknlo
Apr 25, 2002 07:35 AM
