<<<need tranny help quick>>>
Old Mar 23, 2002 | 10:24 AM
airman clutch's Avatar
Default <<<need tranny help quick>>>
last weekend i lost first and second gear in my 95 ex coupe. i aquired a tranny from what i think is a 93 SI this week. finished putting it in last night as well as a new clutch. heres my problem, now the clutch wont disengage enough to get in and out of gear. spent last night and this morning trouble shooting... bled the clutch lines at slave cylinder like 4 times, tried gravity bleeding also. i have a good pedal, and i know the slave cylinder is working. i drove it down the road this morning but had to use the "turn-it-off-put-it-in-gear-start it-" method for every gear. the trans. goes in and out of every gear with the car turned off and feels like it wants to go into gear with the car running but the clutch wont release enough. i appreciate any feedback. i need help today if possible and will be posting this in a couple of other forums. thanx for any help...
cam
Old Mar 24, 2002 | 06:57 AM
GTM's Avatar
GTM
Default Re: <<<need tranny help quick>>> (airman clutch)
Did you resurface the flywheel before putting a new clutch in? Did you replace the throwout bearing? The 2 trannies you swapped are virtually identical interms of clutch engagement. If you have done all the above, then the only other options are to replace the slave cylinder (first) and then the master and rebleed.
Old Mar 24, 2002 | 11:06 AM
gogu's Avatar
im having the same problem with my 94 gsr,i replaced the slave cylinder twice and i still cant figure it out so im just gonna bring it to a tranny shop or an acura dealership
Old Mar 25, 2002 | 11:03 AM
Default Re: <<<need tranny help quick>>> (gogu)
im swappin master cylinder today. i think thats the problem. its the only one i havent tried yet.
lata,
cam
Old Mar 26, 2002 | 04:15 AM
Mista Bone's Avatar
D Tranny Guru
sounds like the clutch disc is on backwards. You didn't need to bleed the clutch hyd. system if you did the swap correctly. You NEVER unhook the hyd. line to the slave unless you are replacing it. Just remove the 2 mounting bolts and lay the slave cylinder over by the fender.
I know PLENTY about S20 trannys.......
http://home.cinci.rr.com/mistab0ne/tranny.html
Old Mar 26, 2002 | 06:37 AM
earl's Avatar
Default Re: <<<need tranny help quick>>> (Mista Bone)
Put the old pressure plate back in and I bet it will shift fine. I think your new pp has the wrong specs. Forget about the new clutch cyl. It doesn't go bad over night.
codybb4
Dec 9, 2008 08:44 AM
viper_boy403
Aug 20, 2008 06:48 PM
GTEC913
Jun 27, 2008 06:29 PM
herbalist
Mar 25, 2005 07:59 PM
airman clutch
Mar 23, 2002 05:26 PM
