Oil around vtec selenoid
Old Mar 23, 2002 | 02:48 PM
SLIMJIMsi97's Avatar
Default Oil around vtec selenoid
I have found little bit oil around my vtec selenoid, someone have ever see this ? Is a gasket or ring between the vtec sel and the block ? Thank's
Old Mar 23, 2002 | 03:17 PM
rainforest's Avatar
Default Re: Oil around vtec selenoid (SLIMJIMsi97)
gasket
Old Mar 23, 2002 | 04:19 PM
IN VTEC's Avatar
It's from the camshaft-end seal on the exhaust cam. You can take it all apart and Hondabond it so it doesn't leak, or replace the seal all together with an OEM part or the STR cam-end plug seal.
Old Mar 24, 2002 | 04:19 AM
Default Re: Oil around vtec selenoid (IN VTEC)
Thanks for helping me, i will verify again if the oil came from the cam end seal or the vtec seal gasket! but 80% sure is from the selenoid....
ramboPandA
Mar 1, 2017 02:58 PM
dwkt
26
Apr 2, 2013 12:57 PM
yoffer
Aug 21, 2012 03:23 PM
Busta16
Jun 17, 2010 12:59 PM
black94lude
Nov 10, 2009 09:11 AM
