Help installing ac on CRx
Old Mar 26, 2002 | 08:19 AM
joy-Ride's Avatar
Default Help installing ac on CRx
I bought a Crx w/a b16A swap w/ no AC...As you can see I live in TX and I have to have a A/C...I dont have the compressor nor the COndensor...Other than that what else will I need...It also has a aftermarket pully that only has room for one belt...so I would probably need a oem pully as well...Thanks for any help and ideas...
Old Mar 26, 2002 | 08:59 AM
Sonic's Avatar
Default Re: Help installing ac on CRx (joy-Ride)
This is going to be a real PITA for you. You need to find a CRX in a junkyard and get off the A/C part under the dash, the lines, the cooling fan, the condenser, and then the compressor from a Del Sol, or a CRX compressor and the bracket from HASport. You also need a switch to turn the a/c on in the car.
Stiff_Crx
Oct 12, 2009 01:34 PM
Stiff_Crx
Jun 16, 2009 08:23 PM
DaCRXboi
Aug 17, 2007 02:39 PM
ryanhejka
Sep 13, 2004 01:58 PM
