Technical question....d series cam selection help!
Old Jun 26, 2003 | 01:04 PM
Rydaddy's Avatar
Default Technical question....d series cam selection help!
For all you d-series junkies who know their stuff - I need help figuring out what cam would be ideal to maximize my setup. Here is a low-down of my setup -
Top end:
Ported and polished z6 head with a .020 mill
Crower valve springs
Skunk2 Ti retainers
Cam gear TBA
Bottom end:
y8 block
y8 rods
a6 pistons
Here is a link with lots of aftermarket cam specs:
http://www.hadamotorsport.com/....html
Now which cam would bring out the best of my setup? Or should I get a cam custom ground? This is a daily driven vehicle, so it has to be driveable and fairly reliable! Thanks for the help!!
Modified by Rydaddy at 4:02 PM 6/26/2003
Old Jun 26, 2003 | 02:23 PM
HYBRID_H@TCH's Avatar
Default Re: Technical question....d series cam selection help! (Rydaddy)
talk to rocket..he makes good cams for the D16 motor and would be able to recommend a good cam for your setup.
Old Jun 26, 2003 | 03:00 PM
Rydaddy's Avatar
Default Re: Technical question....d series cam selection help! (99Hybrid_Hatch)
I talked to him already. he suggested a cam with around a 274 duration, but he didnt mention anything about lift or lobe seperation.
EDIT: I guess I will be a little more specific - I want to have decent low-end power without sacrificing high-end performance. I was looking at the Zex cam, but is there something that would be more suited to my setup?
Old Jun 26, 2003 | 03:55 PM
Rocket's Avatar
For all motor I like 108 lobe separation with the intake at 104-106 centerline.
For peak lift 10.5 - 11.2 is fine is good.
Stock Z6/Y8 springs are plenty for your app.
Becareful with the A6 piston as the Z6/Y8 head has the exhaust valves further to accomodate the vtec mechanism.
Old Jun 27, 2003 | 01:13 AM
Rydaddy's Avatar
Default Re: Technical question....d series cam selection help! (Rocket)
I hope it will work okay....the a1 pistons are sometimes used in these setups and they have big domes compared to the a6. You think I should have it clayed first?
Last thing - Do you have a cam available that you could suggest for my setup?
Old Jun 27, 2003 | 12:40 PM
Rocket's Avatar
The s22 should work well for you.
Old Jun 27, 2003 | 10:15 PM
Rydaddy's Avatar
I was checking that one out, but it states that it is a strong FI cam. Im pretty sure that FI and N/A setups require a different duration, lift, lobe seperation. Would you maybe tell me about the s22?
Old Jun 28, 2003 | 10:46 AM
Rydaddy's Avatar
Little help??
Old Jul 2, 2003 | 10:11 AM
Rydaddy's Avatar
Up again!
Old Jul 2, 2003 | 01:06 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rydaddy &raquo;</TD></TR><TR><TD CLASS="quote">I was checking that one out, but it states that it is a strong FI cam. Im pretty sure that FI and N/A setups require a different duration, lift, lobe seperation. Would you maybe tell me about the s22?
For NA I would modify the lobe centers for you at 108 instead of 114 for the FI version.
Old Jul 2, 2003 | 01:12 PM
Katman's Avatar
Rocket..
have you had a chance to test a Skunk2 SOHC VTEC stage1 cam at all?
Old Jul 2, 2003 | 01:17 PM
Rocket's Avatar
Default Re: Technical question....d series cam selection help! (Katman)
Nope, I heard the lobes are too big and will hit the oil resevoir in the head. I haven't confirmed this.
If anybody has first had experience with this install, please share.
Old Jul 2, 2003 | 01:19 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket &raquo;</TD></TR><TR><TD CLASS="quote">Nope, I heard the lobes are too big and will hit the oil resevoir in the head. I haven't confirmed this.
If anybody has first had experience with this install, please share.</TD></TR></TABLE>
hrm ok..
I recently acquired this cam for my D-project but haven't completed it just yet. Should be running soon.
A6 block, P29 pistons w/stock Z6 head setup.
Old Jul 2, 2003 | 01:28 PM
Rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Katman &raquo;</TD></TR><TR><TD CLASS="quote">
hrm ok..
A6 block, P29 pistons w/stock Z6 head setup.</TD></TR></TABLE>
yeah put the cam in the head with out putting the cam caps on and just rotate the cam to make sure you have clearance.
Old Jul 2, 2003 | 01:38 PM
Katman's Avatar
yeah put the cam in the head with out putting the cam caps on and just rotate the cam to make sure you have clearance.</TD></TR></TABLE>
cool thanks for the D tip.
Old Jul 3, 2003 | 12:09 AM
blackeg's Avatar
ok- this is probably a stupid assumption, but shouldnt the skunk2 cam not hit anything in your head(considering it took long enough to become available). i guess im just edgy because i got one comin in the mail and i spent a good amount of cash on it and i dont wanna run into problems with a stage 1 cam...keep us posted on the install and any thoughts when u get it runnin katman.
Old Jul 3, 2003 | 10:12 AM
Katman's Avatar
Default Re: Technical question....d series cam selection help! (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">ok- this is probably a stupid assumption, but shouldnt the skunk2 cam not hit anything in your head(considering it took long enough to become available). i guess im just edgy because i got one comin in the mail and i spent a good amount of cash on it and i dont wanna run into problems with a stage 1 cam...keep us posted on the install and any thoughts when u get it runnin katman.</TD></TR></TABLE>
I'm assuming the same thing too....
I mean, they should have R&D'd their product, which I'm hoping they did...lol.
I'll keep ya posted.
Old Jul 3, 2003 | 10:42 AM
Rocket's Avatar
They do but I heard the R&D is done by different people than the production.
Old Jul 3, 2003 | 03:47 PM
Rydaddy's Avatar
I've been jacked!!!
Still lookin for some cam help.....can anyone tell me the IDEAL duration/lift/lobe seperation for my setup?? Every cam on that page has different specs - Im assuming one would be more suited for my setup than another...??
Old Jul 5, 2003 | 11:47 AM
Rocket's Avatar
108 LCA and degree the intake to 106.
Eaglekper0046
Mar 18, 2010 01:07 PM
kyle2436
Jun 16, 2008 09:06 AM
mycvc8u2
50
Jul 28, 2003 07:05 PM
mycvc8u2
Jul 26, 2003 10:13 AM
