tranny snap ring
Old Jun 27, 2003 | 06:27 PM
integra95's Avatar
Default tranny snap ring
there is a snap ring on the tranny case that snaps into the out put shaft bearing. How do you get it back on. I have open the rings and push down on the case and its just not going down. How do you guys do it.
Old Jun 27, 2003 | 09:43 PM
SIRX's Avatar
Default Re: tranny snap ring (integra95)
are you using snap ring pliers? I've never had a problem with it.
Old Jun 27, 2003 | 10:27 PM
IN VTEC's Avatar
Do you have it at least partially on the bearing yet? Or is it just floating around freely?
Old Jun 28, 2003 | 12:24 AM
salbaje's Avatar
try moving it back and forth while pushing down on it. i mean the case
Old Jun 28, 2003 | 09:39 AM
integra95's Avatar
I got it so its on the bearing just on the tip of it and now the ring is expanded all the way. I can lift up on the bearing just a little bit but not enough for the snap ring to click in.
Old Jun 28, 2003 | 03:44 PM
eg6h8k's Avatar
it is important to have it snap on..? i know it goes on the side of the bearing but the case is holding the hole brearing in..
Old Jun 28, 2003 | 10:31 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra95 &raquo;</TD></TR><TR><TD CLASS="quote">there is a snap ring on the tranny case that snaps into the out put shaft bearing. How do you get it back on. I have open the rings and push down on the case and its just not going down. How do you guys do it.</TD></TR></TABLE>
once you place the upper tranny case, you'll notice that the case will slide down but it will stop short of closing completely. using a needle nose plyers, or a snap ring pliers spread that snap ring on the countershaft bearing. once you do this, push down on the case until the snap ring gets stuck open on the bearing. you can push down on the case to fully close it, if it does not fully close use both hands to hold both halfs of the case from separating and tilt the tranny until the countershaft slides down and the snap ring locks in place. before you do all this, make sure you coat the edge of the tranny case with hondabond! good luck!
Old Jun 29, 2003 | 09:18 AM
integra95's Avatar
Default Re: tranny snap ring (smokey2.0)
here is my deal the case is all the down and the bolts are put in the snap rings are not in place. I is settin on the bearing but not in place.
Old Jun 29, 2003 | 09:19 AM
Colin's Avatar
what gear is the tranny in? When i took my ys1 apart I have having a hell of a time getting the case to go down that last couple mm. I took the case off again and went through the instructions in the helms again to double check. I'd done everything right, except for about 4 or 5 steps back it had said to put the tranny in 4th gear....it didn't seem to be important for that step so I didn't bother. But this time I figured i'd try anything. Shifted it into 4th....and bam, case slid right over, with ease even
Old Jun 29, 2003 | 06:27 PM
IMALLSLO's Avatar
Sounds strange but flip the tranny over onto the side that has the snap ring.....and <u>gently</u> drop it a few times. Usually the bearing will slide down along with the gear shaft and the ring will fall into place. Old trick the Dr. showed me. Works everytime. Good luck.
Old Jun 29, 2003 | 11:25 PM
IN VTEC's Avatar
Default Re: tranny snap ring (proclassracer)
That's kinda what we did. Just let the tranny fall onto the wood planks a couple of times and it made its way into the groove after we had the clip around the bearing sleeve.
Old Jun 30, 2003 | 05:32 AM
EFSiR's Avatar
Make sure that the main shaft oil guide plate (plastic) is not off to the side being squished by the bearing. If you don't have the ring snap on with the case bolts in , something is very wrong, take it apart again.
solo-x
29
Aug 30, 2005 02:56 PM
Mr_Moos
Apr 19, 2005 10:07 AM
rice a roni
Feb 3, 2005 06:48 AM
MAD SCIENTIST
Jun 8, 2003 06:26 AM
