Signs of a bad starter?
Old Jun 28, 2003 | 02:58 PM
liquid51's Avatar
Default Signs of a bad starter?
Obviousely, when it won't turn the engine over and you know you've got a solid 12v. But does it just give the typical dead battery click? All I'm getting is the click, and I know I'm at 12v. How typical is a bad starter on swaps? And it's only a '00. Seems like 3 years is a short life for a starter.
Old Jun 28, 2003 | 10:32 PM
LV's Avatar
LV
Default Re: Signs of a bad starter? (liquid51)
To really check your battery, YOu need to put a load on it. Bring it to a shop and have them check your battery. If is not your battery then check your starter cable for loose or bad connection. If everything is good then is your starter.
Old Jun 28, 2003 | 10:55 PM
liquid51's Avatar
Default Re: Signs of a bad starter? (LV)
the battery is a brand new Odyssey 680. And I put it on the charger for a bit too make sure it had a good charge. So I'm assuming it's not my battery. Guess I'll triple check my connections and see if it isn't the starter.
Thanks
Old Jun 29, 2003 | 10:29 AM
1titesol's Avatar
Sometimes you can tighten the power wire nut too tight, and cause the internals inside the starter to turn. I've done it before and it was very easy to fix. I took it to a friend of mine that works on starters and alternators. I recomend you do the same thing. Unless you have some knowledge on starter internals. Good luck, it sounds like the same deal I went threw.
Old Jun 29, 2003 | 11:56 AM
liquid51's Avatar
Default Re: Signs of a bad starter? (1titesol)
thanks for the info man. I'll look into that. hopefully it is that easy and not some bigger problem.
J1MMY420
May 16, 2014 08:46 PM
dvlsfan30
Feb 11, 2009 09:45 AM
nesabay
May 17, 2005 08:39 PM
sparxx
Jan 6, 2004 02:46 AM
l
Jul 31, 2002 04:37 PM
