IAT question
Old Jun 29, 2003 | 12:59 AM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default IAT question
other than reporting intake manifold temp to the ECU.. what does the ECU use this info for? i heard.. but im not sure that.. the hotter the engine is.. or intake temp, it adjusts the timming? retards it for hot? or something? does anyone know the background of this sensor? and would it be possible to bypass it.. if timming was stright up all the time, that would be ok.
Old Jun 29, 2003 | 01:06 AM
MaxSterling's Avatar
Default Re: IAT question (Built B16A)
it adds fuel and adjust timing. MAP, tps, and iat all work together.
Old Jun 29, 2003 | 08:29 AM
577HondaPrelude's Avatar
Default Re: IAT question (keith_phan)
it's used to calculate the amount of air entering your engine. With the ECU knowing air temp (IAT), air pressure (MAP), and engine speed, it can calcuate the mass air flow. Some cars use a mass air flow sensor for this but honda calculates it. like stated above it then uses this info to adjust fule, and in an obd2 car also timing.
journeyquest
Aug 21, 2010 08:50 PM
standbackimapro
Jan 24, 2009 07:53 AM
BoRiCuA
Sep 28, 2007 11:05 AM
AnAccordIsForever
Nov 27, 2006 08:31 PM
austrian type-R
Sep 17, 2001 12:41 PM
