how to hold the axle still while tightening nut
Old Jun 27, 2003 | 03:47 PM
Audipwr1's Avatar
Default how to hold the axle still while tightening nut
using the wheel studs seems to strip them out
is there another way to hold the axle still while tigthening the axle nut
Old Jun 27, 2003 | 04:05 PM
IN VTEC's Avatar
Default Re: how to hold the axle still while tightening nut (Audipwr1)
Lots of ways.
Step on the brakes. Might not be enough to prevent the wheel from turning.
Lock the flywheel or the crank pulley.
Impact them on.
Old Jun 27, 2003 | 04:10 PM
MaxSterling's Avatar
Default Re: how to hold the axle still while tightening nut (IN VTEC)
hand tight the spindle nut, and put on rims with center piece off. lower car. can then torque down spindle nut to specs
Old Jun 27, 2003 | 04:11 PM
servion's Avatar
Stick a screwdriver inside the hole on the outside of the caliper (there's an opening in the caliper where you can see through to the the rotor) and into the rotor. Works like a charm
Old Jun 27, 2003 | 04:14 PM
Audipwr1's Avatar
Default Re: how to hold the axle still while tightening nut (servion)
got it thanks
Old Jun 27, 2003 | 07:49 PM
IN VTEC's Avatar
Forgot about that method. That definitely works.
Old Jun 27, 2003 | 07:58 PM
Stripped Honda's Avatar
99-0104
air tools own joo
Old Jun 27, 2003 | 07:59 PM
.RJ's Avatar
.RJ
Default Re: how to hold the axle still while tightening nut (Stripped Honda)
so do cordless impact wrenches
Old Jun 28, 2003 | 01:51 AM
Turbo92Si's Avatar
Default Re: (GSRslowandswap)
_______
works all the time
Old Jun 28, 2003 | 03:24 AM
Audipwr1's Avatar
Default Re: (Turbo92Si)
got it right after i asked it, just hooked up the brakes
Old Jun 28, 2003 | 08:51 AM
Blaze45's Avatar
Brrraaaap!
Default Re: (Audipwr1)
You could also brake em b4 you take the car off the ground.... Works even better!
Blaze
aowpsycho
Aug 30, 2009 07:11 PM
itr1244
Apr 14, 2008 12:25 PM
wdskuk
16
Jul 25, 2004 12:21 AM
david90
May 25, 2004 04:01 AM
253EK
Jan 12, 2004 06:44 AM
