Which Pistons to use??
Old Jun 28, 2003 | 02:09 AM
ek9lau's Avatar
Default Which Pistons to use??
At the moment I have a Spoon stroker kit for my ek9 (which bascially are the ITR pistons, rods and crank but balanced and a spoon head gasket) and Jun 3 camshaft kits waiting to be fitted. But I still cannot decide to use the original ctr piston or use the spoon itr pistons or buy some Toda high compression forged pistons. Because I have heard that the Jun cams like high compression.
I want higher compression to give more bhp, but I have also heard that it requires more work to the block to fit the ctr pistons with the itr rods and it could be risky running too high compression with the Jun cams and the thin gasket. Is this true??
Did anyone have any problems with fitting ctr pistons into your ITR block, did it require more labour work. Because I have heard that it can cause some pistons and valves clearancen problem. Are you using any thinner head gasket? Is it not ideal to run thinner head gaskets because of the high compressions?
Please tell me what do you think of my set up, and what pistons would you recommend?
Please any suggestion and help?
Thanks in advance for any help
Old Jun 28, 2003 | 02:36 PM
ek9lau's Avatar
Default Re: Which Pistons to use?? (ek9lau)
Please anyone, any suggestions???
really need to know which is the best set up??
Shall I get some Toda pistons??
Thanks
Old Jun 28, 2003 | 04:13 PM
aeolus's Avatar
if you do getsome toda pistons or whetever piston, make sure you clay the block to make sure your valves wont hit the piston tops.
Old Jun 28, 2003 | 05:44 PM
joe_bocc's Avatar
You are right about the risk of running high lift cams, thin head gasket, and high CR pistons all in the same set-up, but if you do like already suggested, clay the motor, you would be safe.
CTR should not be any different to install than ITR pistons. It is true that they will cause a higher risk of piston-valve contact, but claying the motor will check that for you.
If you don't plan on running a lot of nitrous, if any, then I say go with the CTR pistons. The Toda pistons are very expensive and they cause a very hign CR.
Old Jun 29, 2003 | 12:29 AM
ek9lau's Avatar
Default Re: Which Pistons to use?? (joe_bocc)
Thanks for that.
Forgive me for being dumb, but what is claying. Is it expensive to do???
Do I still need to clay the block if I use the spoon ITR pistons??
Thanks
Old Jun 29, 2003 | 12:50 AM
gsrvx's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9lau &raquo;</TD></TR><TR><TD CLASS="quote">
but what is claying.</TD></TR></TABLE>
Here ya go....this should help:
http://www.c-speedracing.com/h...y.php
Old Jun 30, 2003 | 12:03 AM
ek9lau's Avatar
Default Re: Which Pistons to use?? (RK)
Thanks for the link.
Thanks
ek9lau's Avatar
Thanks
Old Jul 1, 2003 | 07:16 PM
granada_sun's Avatar
man claying the block looks like a lot of work but very effective..wish i had the time to check with ctr pistons, jun 3's and b16 head milled .020 on ls block
PowerHouse
Oct 12, 2004 06:21 PM
Thrashin
Nov 18, 2003 09:50 PM
texasSI
Nov 2, 2002 05:29 PM
COREY ITR#625
Nov 21, 2001 07:55 AM
comptechgsr
Jun 25, 2001 01:02 PM
