Tech help needed please. Motor runs like crap.
Old Oct 24, 2003 | 06:23 AM
Red D Dragon's Avatar
Default Tech help needed please. Motor runs like crap.
Ok here is the story. I installed a b18c1 mtoor in my hatch like 5 weeks ago already and it still doesn't run right. I haven't been able to figure out whats wrong with it. I need some tech help please. Ok car idles a little rough and when i try and drive it it has no power and runs really really rough. I checked the timing and it is about 16degrees btdc and my car idles at about 1,000 rpm The wires are good. The check engine light is on but when i go to loop the service connector for a CEL code all that happens is my srs light blinks in no pattern. I hooked up the two vtec wires, the knock sensor and made a chasis ground for my vtec press switch. I have a skunk2 intake manifold so the plug for the dual butterfly isn't plugged in anywhere and the evap purge i hooked up the red wire but not the power wire. Please any help would be awesome. I am really starting to get pissed off.
Old Oct 24, 2003 | 07:21 AM
JimBlake's Avatar
Default Re: Tech help needed please. Motor runs like crap. (Red D Dragon)
So when you jumper the SCS nothing different happens to the CEL? Is the SCS OK? On my '95 it's connected to D-4. I don't know if that's different for OBD-2 B18C1 ECMs. Jumpering the SCS is exactly the same as shorting D-4 to ground.
Old Oct 24, 2003 | 07:24 AM
Ya the SRS is ok.. and i tried shorting to ground on the connectore and the same thing happens just my srs light blink and check engine light stays on.
Old Oct 24, 2003 | 07:56 AM
spaceman's Avatar
first of all make sure all wires go to where they are supposed to go and done correctly,check all your grounds,fuses,try to do a tune-up,make sure your timing is good...etc.
Old Oct 24, 2003 | 05:35 PM
Ya it was the wiring . I went off of a bad wiring diagram off the internet... It was totally wrong and i had a bunch of wires that were messn **** up. But now it runs really well just need lots of tuning.
juanintec
Aug 10, 2007 05:11 PM
92civicboost
Feb 28, 2007 02:46 PM
Phink
31
Aug 27, 2003 06:02 PM
LXguy
Apr 26, 2002 11:32 PM
