Swapping Heads- Do I need new head bolts?
Old Oct 22, 2003 | 03:12 PM
cbstd's Avatar
Default Swapping Heads- Do I need new head bolts?
I am going to swap out my stock head for a ported and polished head on my D15A3. Do I need to order new head bolts or can I resue the old one?
Many thanks for the info.
Scott
Old Oct 22, 2003 | 03:40 PM
03ephatch's Avatar
Default Re: Swapping Heads- Do I need new head bolts? (cbstd)
new gasket... new bolts... ic them as a necessity. 2 cents
Old Oct 22, 2003 | 07:47 PM
mmuller's Avatar
Mad Scientist
Default Re: Swapping Heads- Do I need new head bolts? (03ephatch)
i've taken my old ones out plenty of times and no problems.
Old Oct 22, 2003 | 09:38 PM
vtecmike1's Avatar
you 100% definatly need a new head gasket however the head bolts can be ruesed... i would only reuse them once though and then replace them with oem or aftermarket studs will do.
Old Oct 22, 2003 | 11:26 PM
03ephatch's Avatar
r u swapping another head? or using the same? i did a mini-me, used new oem head bolts... just to be on the safe side. if not, heck, why not try using the same one.
Old Oct 23, 2003 | 05:19 AM
civicmatt's Avatar
I reused head bolts. Put them back in the same hole they came from with a few drops of light weight oil. Clean the hole first with a rifle bore cleaner on a drill and then blow out the hole with compressed air. Also clean the threads on the bolts really well with a wire wheel. Good luck.
Old Oct 23, 2003 | 06:03 AM
shogunofthedark's Avatar
It is always best to get new head bolts, if not the dangers of blowing your new head gasket are greatly increased, and like civicmatt suggested ALWAYS coat the threads of the new bolts before installing them. This is so that you can get the correct torque. If you don't use oil then the torque wrench will give a false reading because of friction. Good Luck!
Old Oct 23, 2003 | 06:44 AM
Toxidomask's Avatar
I would get the bolts, you want to do the job right, do it right the first time so you wont have problems. Also sometimes the threads on those? they stretch even though you dont see it well, they do; thats due to torqeing of the head.
89 SI zero
10
Apr 19, 2013 03:01 PM
Soccerking3000
Sep 1, 2004 06:29 PM
tuan...
Nov 28, 2003 02:43 PM
