copression????
Old Oct 23, 2003 | 05:56 PM
Modifiedinteg's Avatar
Default copression????
i did a copression test on my 99' integ with 71000 miles. the reading was #1 180, #2 165, #3 165, and #4 170. im all so at 5200 feet elevation does it effect my copression since there is less air up here
Old Oct 23, 2003 | 06:06 PM
FasteddieIX's Avatar
Default Re: copression???? (Modifiedinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Modifiedinteg &raquo;</TD></TR><TR><TD CLASS="quote">i did a copression test on my 99' integ with 71000 miles. the reading was #1 180, #2 165, #3 165, and #4 170. im all so at 5200 feet elevation does it effect my copression since there is less air up here</TD></TR></TABLE>
yes.. thinnner air = more air needed in chamber to optimize compression. Higher the altitude, the suckier your compression.
Old Oct 23, 2003 | 06:22 PM
Default Re: copression???? (FasteddieIX)
so... is at at spec i need to know if im loosiing more copression then i need to
Old Oct 23, 2003 | 08:22 PM
any one out there to help me out?
Old Oct 23, 2003 | 08:28 PM
Lord Helmet's Avatar
you're within specs for the compression. btw you didn't tell us which engine you have? b18c1 or b18b? for the b18b that would be a reasonable compression #'s for the b18b. now for the b18c1 your at the lower end BUT still within specs.
Old Oct 23, 2003 | 09:26 PM
chrisCNL's Avatar
did you have the throttle body open fully when you did the compression test... also pour like a cap full of engine oil in to each cylinder...if the compression goes, i think your nos f... up your motor.. rings going bad...
Old Oct 24, 2003 | 10:14 PM
Default Re: copression???? (chrisCNL)
no i forgot to have the throttle wide open though. can that effect any thing?
duf2570
Oct 18, 2012 01:20 AM
youknowimwhite
Apr 6, 2007 05:16 PM
NuclearB18B
Jul 2, 2005 03:01 PM
93H22ACX
Jul 15, 2004 02:33 AM
V8'suck23
Apr 3, 2003 08:11 AM
