need info for obd2 to obd1 conversion
Old Oct 22, 2003 | 12:37 PM
Civic's Avatar
Default need info for obd2 to obd1 conversion
going to be doing an obd2 to obd1 conversion on a 99-00 si but need to doublecheck the parts that i will need. so far, this is what i know for sure that i will need:
obd2 to obd1 harness
obd1 vtec b series ecu
92-95 civic ex/si engine harness
obd1 distributor
obd1 alternator
i am unsure as to if i will also need an obd1 starter? if i've forgotten any other parts, please let me know. thanks.
Old Oct 22, 2003 | 12:50 PM
Katman's Avatar
Default Re: need info for obd2 to obd1 conversion (Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic &raquo;</TD></TR><TR><TD CLASS="quote">going to be doing an obd2 to obd1 conversion on a 99-00 si but need to doublecheck the parts that i will need. so far, this is what i know for sure that i will need:
obd1 distributor
obd1 alternator
i am unsure as to if i will also need an obd1 starter? if i've forgotten any other parts, please let me know. thanks.</TD></TR></TABLE>
ok your off on some stuff.
All you really need is the OBD2b-&gt;1 jumper harness and OBD1 ecu. That's it. Everything else you can leave OBD2 on the engine; that includes all of the electronics, fuel injectors, engine harness etc, the OBD1 ecu is compatible with OBD2 electronic/ignition parts. An OBD1 engine harness is not compatible with any EK civic/civic coupe, you have to use an EK engine harness in an EK.
If you need the jumper harness & a reprogrammed P28 ecu, hit me up I sell both of those items.
Old Oct 22, 2003 | 01:23 PM
Civic's Avatar
Default Re: need info for obd2 to obd1 conversion (Katman)
ok, i think i left some info out. we are swapping out the obd2 block for an obd1 block, still a b16a. keeping the obd2 head. will i still only need the ecu jumper and ecu?
Old Oct 22, 2003 | 03:52 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic &raquo;</TD></TR><TR><TD CLASS="quote">ok, i think i left some info out. we are swapping out the obd2 block for an obd1 block, still a b16a. keeping the obd2 head. will i still only need the ecu jumper and ecu?</TD></TR></TABLE>
yes, thats the main ingredient, the jumper & an OBD1 ecu. Make sure you stick with an OBD2 engine harness and ignition though.
Old Oct 22, 2003 | 04:23 PM
Civic's Avatar
alright. that's less money to be spent. thanks.
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
BoltonGSR
Jun 13, 2008 08:49 PM
h22_crx
Mar 4, 2007 02:17 PM
turbozc3g
Jun 6, 2005 07:34 PM
90Zcrx
Nov 19, 2002 11:26 PM
