Type r Prop vavle?? HELP!!!
Old Oct 25, 2003 | 11:14 AM
daddymaxx's Avatar
Default Type r Prop vavle?? HELP!!!
Ok, So I installed my 5 lug and it's great so far. I installed all four corners and the new booster and master cylinder....
But my prop vavle I have on there has 6 lines going into it. While my type r porp vavle only has 4.....
How am I supposed to use this?
Old Oct 25, 2003 | 10:42 PM
daddymaxx's Avatar
Default Re: Type r Prop vavle?? HELP!!! (daddymaxx)
nobody?
Old Oct 25, 2003 | 10:54 PM
mmuller's Avatar
Mad Scientist
what car?
if you have drums in the back you'll have to use a civic si one
Old Oct 26, 2003 | 07:57 AM
redStorm's Avatar
Your problem is that all ITR were equiped with ABS and the proportionning is done in the ABS module ( not by the valve ).
What car do you have... if it's a 4th, 5th gen civic or 97- Teg, you need a prop valve from a 92-95 Civic SI Hatch, or 90+ Integra Without ABS. It has the same shape as your stock prop valve but it's stamped 4040 (of 3040 in case of the 92-95 civic SI hatch) instead of 3030
Hope it helps.
Olivier
Old Oct 29, 2003 | 12:15 AM
daddymaxx's Avatar
I have a 97 EK hatch
Old Oct 29, 2003 | 06:11 AM
redStorm's Avatar
Default Re: (daddymaxx)
I'm pretty sure my explanation still stands for a 97 EK.
However, do a search on this forum... this topic has been discussed a couple times already.
Olivier
95_GSR_SEDAN
29
Nov 15, 2009 12:21 PM
young geezer
Sep 29, 2007 04:55 PM
2wheelhunter
Mar 23, 2007 08:29 AM
willyboyK20
Sep 22, 2003 08:51 PM
2.2
Jul 18, 2002 07:51 PM
