check engine light code 43
Old Oct 22, 2003 | 08:06 AM
urgonnalearn2's Avatar
Default check engine light code 43
How do i fix this to clear the code it says fuel supply malfuction, please let me know asap, thanks
Old Oct 22, 2003 | 10:54 AM
Downey's Avatar
Default Re: check engine light code 43 (urgonnalearn2)
give us some more info on your car? are you runnin a turbo b16 using the stock DX fuel pump or somthing? more info and then we can help you out.
Old Oct 22, 2003 | 08:09 PM
Default Re: check engine light code 43 (Downey)
95 integra is the car stock
Old Oct 23, 2003 | 04:45 AM
EE_Chris's Avatar
If the car is stock, and you've got mileage on it (>100k), I'd suspect your O2 sensor is showing its age.
Old Oct 23, 2003 | 11:20 AM
Roger's Avatar
Default Re: check engine light code 43 (EE_Chris)
code 43; fuel supply system. Check the fuel pressure and fuel pressure regulator. Also check to see if there are any vacuum leaks.
Jahmani
Nov 9, 2018 03:53 PM
nv707
Oct 7, 2007 06:11 PM
gsr converters
Sep 13, 2006 10:08 PM
KseriesGRL
Jan 16, 2004 07:42 AM
monsoon
Nov 21, 2002 08:54 PM
