differences b16/b18 headers
Old Oct 26, 2003 | 05:16 AM
IVI's Avatar
IVI
Default differences b16/b18 headers
what are the diffrences between a b16 header and a b18 header? does the pipe sit a little bit lower? i heard that all b-series parts are interchangeable, but i am not so sure anymore after trying to get axles for a b16. however a b18 axle did fit, but it was hell getting the correct part. i have an integra with a b16 motor in it. the headers are made for a b16 but the bottom part of the header sits pretty low under the car where is it lower then the rest of the chassis. 2 pipes on my header are completely crushed / caved in because of that. i am curious if i get a b18 header because my car is a gsr, will it fit the body better and not be lower to the ground like the b16 header is?
Old Oct 26, 2003 | 07:10 AM
mathusala's Avatar
Default Re: differences b16/b18 headers (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">what are the diffrences between a b16 header and a b18 header? does the pipe sit a little bit lower? i heard that all b-series parts are interchangeable, but i am not so sure anymore after trying to get axles for a b16. however a b18 axle did fit, but it was hell getting the correct part. i have an integra with a b16 motor in it. the headers are made for a b16 but the bottom part of the header sits pretty low under the car where is it lower then the rest of the chassis. 2 pipes on my header are completely crushed / caved in because of that. i am curious if i get a b18 header because my car is a gsr, will it fit the body better and not be lower to the ground like the b16 header is? </TD></TR></TABLE>
A b18 header will be even lower (u could already have 1 and u just don't know it). if you want a better fit get rid of the 4-1 and get a 4-2-1.
MaGoodc2
May 3, 2006 02:25 PM
the.hamburglar
Feb 12, 2006 10:55 AM
PureEF8
Jun 16, 2005 03:21 PM
