B16 heads
Old Oct 22, 2003 | 05:48 AM
mdelena's Avatar
Default B16 heads
I keep hearing about which one is which & I'm still not sure.
Does anyone have the end all list of B16 heads?
I'm thinking about a cr-vtec & this seems to be the cost effective head for this
combo but I'm unsure which casting # I'm after......how many are there? Which one's share the same castings? Is there any real difference in them after a pro porting job?
Thanks
Old Oct 22, 2003 | 05:51 AM
turboxsi's Avatar
Default Re: B16 heads (mdelena)
Pr3 is the most commonly use b16 head, b/c it shares the same casting as the ITR head.
Old Oct 22, 2003 | 06:01 AM
rsbad454's Avatar
Default Re: B16 heads (turboxsi)
as far as i know......all B16A heads ar ethe same..........ITR and CTR heads and hand ported from the factory.
Old Oct 22, 2003 | 10:35 AM
mmuller's Avatar
Mad Scientist
Default Re: B16 heads (rsbad454)
yeah you have pr3 and p72(gsr)
there is minor differences between newer and older pr3 heads.aside from cams and electronic stuff; older pr3 heads have extrude cam caps and newer have machined. also older pr3's have less casting flaws.
Old Oct 22, 2003 | 12:00 PM
Deetz's Avatar
Crazy Honda Guy
I can't remember where i sourced the info, but yes the 1st gen B16A head seems to have the best casting, but the weakest cams (hp wise). Use a good set of aftermarket cams like Shunk II, and perhaps some better springs, and you'll have a very good top end.
Old Oct 22, 2003 | 12:05 PM
rsbad454's Avatar
Default Re: (Deetz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deetz &raquo;</TD></TR><TR><TD CLASS="quote">I can't remember where i sourced the info, but yes the 1st gen B16A head seems to have the best casting, but the weakest cams (hp wise). Use a good set of aftermarket cams like Shunk II, and perhaps some better springs, and you'll have a very good top end.</TD></TR></TABLE>
as far as the spray bars and casting i agree, but only automatic heads had the weaker cams........SirII had the better cams out of the B16A's.......
kevheslop
Sep 23, 2009 10:43 AM
92b16si
Nov 18, 2004 05:13 PM
krazydc_audio
Oct 8, 2004 08:49 PM
BoostinDC2
Sep 18, 2001 07:03 PM
