ls motor back in ls and not starting
Old Oct 21, 2003 | 12:15 PM
warwagon's Avatar
Default ls motor back in ls and not starting
ok i have the stock motor bolted back in my car and when i go to start it everything sounds good and it just wont hit. if you throw some gas in the intake it will hit but other than that it wont start. gas is flowing through rail and the pump is pumping. any suggestions would be greatly appreciated
Old Oct 21, 2003 | 12:41 PM
Project92Hatch's Avatar
Default Re: ls motor back in ls and not starting (warwagon)
Does it crank? If it does but doest start check you distrib. To see if its all the way one there you could have the thing that turns on the distrib up side down. OR could be a bad ground.
Old Oct 21, 2003 | 09:19 PM
warwagon's Avatar
bump, the injectors are dry and i am clueless/tired/sick of working on this damn car
Old Oct 21, 2003 | 09:22 PM
turboxsi's Avatar
Do you know if you getting any spark?
Old Oct 21, 2003 | 09:24 PM
warwagon's Avatar
Default Re: ls motor back in ls and not starting (turboxsi)
getting spark, but its like the injectors arent even spraying, tried a second ecu, and fuel is running through the rail
Old Oct 21, 2003 | 09:27 PM
bryan305's Avatar
How do you know fuel is running through the rail?
Old Oct 21, 2003 | 09:31 PM
warwagon's Avatar
Default Re: ls motor back in ls and not starting (bryan305)
because when i pull the recirculate hose off and turn the key on it shoots out of the fpr
Old Oct 21, 2003 | 09:41 PM
b19coupe's Avatar
Check to make sure that you bolted up the ground wire by the thermostat-then check all of your connectors.
Old Oct 21, 2003 | 09:46 PM
warwagon's Avatar
Default Re: ls motor back in ls and not starting (b19coupe)
thermo is grounded, which connectors should i quadruple check
Old Oct 21, 2003 | 09:49 PM
b19coupe's Avatar
All of the connectors on the shock towers. Usually when something like this happens, it is something simple that you overlook. When you finally find it, it's like duh!
Old Oct 21, 2003 | 09:51 PM
warwagon's Avatar
yeah i know what you mean i have left that damn tranny ground off before and about kicked my own ***
Old Oct 22, 2003 | 03:04 AM
jde_07's Avatar
I would check all your grounds and make sure they are tight that stupid tranny ground wasn't completly tight for me once and the would start but run like crap and I luckily stumbled acrossed it acidently and it made me feel like a complete jackass also check to make sure the ecu is plug in all the way. that is if you are getting spark, fuel, and compression.
Boosted_90Teg
Jan 6, 2013 02:33 PM
EGcivic_95
10
Feb 25, 2012 05:02 PM
psychx
Jul 3, 2011 10:46 AM
Happyfeat2006
Sep 29, 2008 08:24 PM
boostaholic
Jul 2, 2002 08:49 PM
