Starting problems after installing walbro fuel pump
Old Oct 22, 2003 | 03:12 AM
h22civic95coupe's Avatar
Default Starting problems after installing walbro fuel pump
Its a honda civic coupe with not tuned h22a2 engine, fuel pressure regulator was installed before the pump and everything was working fine, except for of course civic fuel pump couldnt allow enough pressure for that engine, so after like a month, civic fuel pump was replaced with a walbro 255lph fuel pump, i drove the car for like a full day , and everything was perfect, smooth acceleration, no lags; but after leaving the car sitting for about 3 hours i started the car and heard a weird noise coming from the fuel pressure regulator, so i restricted the fuel flow a little bit, but the car would stumble as i gave it more throttle, so i had to adjust it back to normal, but it started doing the same thing. After playing with the fpr a couple more minutes i tried to start the car and it just wouldnt.An hour later i managed to start it for the first time (it was working rough, like a tractor, so i gave it a little bit of throttle, but it just died out again), so i started it like that again and tried to adjust the fpr while its working to reduce the pressure, with a smallest turn of the adjustment screw the car died out and just wouldnt start again nomatter how i adjusted the screw. I have no fuel pressure gauge so i cant actually see what pressure its at and if there is pressure at all. I can hear the fuel pump priming when i turn the key.Is there a way to check if its fuel pressure regulator thats fucked, or maybe its something else and someone had the same situation?
Old Oct 22, 2003 | 04:38 AM
JimBlake's Avatar
Default Re: Starting problems after installing walbro fuel pump (h22civic95coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic95coupe &raquo;</TD></TR><TR><TD CLASS="quote">... Is there a way to check if its fuel pressure regulator thats fucked?...</TD></TR></TABLE>The way to check is with a fuel pressure gauge. You might want to get one.
Old Oct 22, 2003 | 05:19 AM
rsbad454's Avatar
Default Re: Starting problems after installing walbro fuel pump (JimBlake)
no ****.......why would you have an adjustable FPR with no guage? kinda defeats the purpose. what brand FPR is it?
Old Oct 22, 2003 | 04:18 PM
Well i kind of thought of it as well, but hell, there aint an fpr in England with a built in gauge, and i couldnt find a gauge either, so i was left with 2 choices and went for the one that was quicker and figures i lost.
Old Oct 22, 2003 | 08:31 PM
eg:R's Avatar
you turned your psi on the guage to low, when there is now enought fuel going in, the car will bog, turning it the other way, but you really need to get a fuel pressure guage, go to ebay for one
Old Oct 23, 2003 | 05:18 AM
rsbad454's Avatar
Default Re: (h22civic95coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22civic95coupe &raquo;</TD></TR><TR><TD CLASS="quote">Well i kind of thought of it as well, but hell, there aint an fpr in England with a built in gauge, and i couldnt find a gauge either, so i was left with 2 choices and went for the one that was quicker and figures i lost.</TD></TR></TABLE>
so order one from somewhere, i cant stand not being able to see whats going on i bought mine from http://www.summitracing.com
Thagoldenb
Jun 3, 2011 05:51 PM
95ITRJDM
Apr 10, 2011 06:09 AM
iNetForce
Nov 13, 2005 08:27 PM
VNTEC
Jul 6, 2004 06:45 AM
h22civic95coupe
Oct 22, 2003 04:15 PM
