how much compresion is to much for boost
Old Oct 23, 2003 | 07:29 AM
4nmusle's Avatar
Default how much compresion is to much for boost
I have a mild ls setup eagle rods,ross(11.5-1) pistons,the run of the mill head job nothing special my ? is has anybody ever boosted such a high comp setup before
or would the cyl pressure be too much???
thanks for any input
Old Oct 23, 2003 | 12:55 PM
4nmusle's Avatar
ttt
Old Oct 23, 2003 | 02:15 PM
7thGear's Avatar
Default Re: (4nmusle)
you would need race gas, **** race gas, you would need jet fuel and a SUPER TUNED fuel map
Old Oct 23, 2003 | 02:26 PM
importfan's Avatar
I think a few pounds, between 5-7 of boost would respond awsome. you could even use a healthy size turbo and not worry about lag since all that compession would help out on the low end and boost on the high end. But like others suggested, tune that fuel. Also a btm would help with the timing issue.
Old Oct 23, 2003 | 02:30 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: how much compresion is to much for boost (4nmusle)
many of the honda drag race engines are using higher compression ..BUT race fuel ..really good tuning is what makes it possible to be stable.to run high boost...ive seen a few turbo rsxs and there stock comp is 11.1 i beleive, but they have to boost like 3-5psi and still require great tuning with pump gas..if u want to keep your setup. i suggest an inline pro thick turbo head gasket...
Old Oct 23, 2003 | 02:43 PM
7thGear's Avatar
Default Re: how much compresion is to much for boost (bruceleeroy)
what about superchargers + high comp engines? would that work? since most superchargers arent pushed past 7-8 psi?
hotimportcrx
17
Dec 5, 2005 04:52 PM
FullBoostAhead
Feb 10, 2004 01:51 PM
Spooled1.6L
Feb 4, 2004 05:40 AM
smoothludey2
May 9, 2002 02:58 PM
slowcivic
Dec 14, 2001 10:12 AM
