How to replace a front bearing ?
Old Oct 23, 2003 | 03:37 PM
Garrett's Avatar
Default How to replace a front bearing ?
I look to replace the front bearing on my 99 teg knuckles but I don't find how to remove them.
Help will be very usefull
Old Oct 23, 2003 | 04:58 PM
80884's Avatar
Default Re: How to replace a front bearing ? (Garrett)
wheel bearing? i belive you have to press them out, and in. hydrolic press.
Old Oct 23, 2003 | 05:17 PM
Garrett's Avatar
**** it seem to cost alot of money
Old Oct 23, 2003 | 09:20 PM
chrisCNL's Avatar
Default Re: (Garrett)
two ways...have a shop that knows what they are doing to press out the hub and bearing or....use some a super big sockets and **** the hub and the studs up. it should be pretty cheap if you already got the knuckle and spindle off teh car with the new bearing.
Old Oct 23, 2003 | 09:26 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (chrisCNL)
You can remove the entire assembly (suspension) as a whole and bring that to a shop for them to press it out.
Old Oct 24, 2003 | 01:11 AM
camboMONK's Avatar
Default Re: (shamoo)
take to the shop. it's only $90 and they do it in about an hour.
Old Oct 24, 2003 | 09:11 AM
Audi RS4's Avatar
Lover
they need to be pressed out and the new ones pressed in!! it is not that expensive
RacerTim
Sep 10, 2010 05:44 PM
ToTriggerHappy
May 3, 2010 04:50 AM
taylorjohnson11
Nov 14, 2007 07:40 PM
Bnjmn
Sep 20, 2005 03:43 PM
low430
Aug 29, 2005 08:32 AM
