took apart the motor
Old Oct 24, 2003 | 07:16 PM
omega11855's Avatar
Default took apart the motor
well i completely took apart my motor im the one with the knock well all the bearings on the bottom end were toast but none were physically spun into a different place also the bearings in the head had little nicks on the cam caps (bearings) and the bottom part of the bearing which is actaully part of the head what do i have to do can the be polished out or do i have a bigger problem i need help pretty bad im pretty mechanical compitent so just let me know what i need to do about the small knicks that appear in some of the cam journals
Old Oct 24, 2003 | 09:16 PM
omega11855's Avatar
someone has to know what im talking about anyone?
Old Oct 24, 2003 | 09:22 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: took apart the motor (omega11855)
u can actually have that part of the head align honed just like they do the mains in blocks...try a local machine shop.....hopefully your "nicks" arent to deep.
Old Oct 26, 2003 | 03:03 PM
omega11855's Avatar
Default Re: took apart the motor (bruceleeroy)
what do you think?
Old Oct 26, 2003 | 03:07 PM
mmuller's Avatar
Mad Scientist
you cant really see the pic good, but the cam journals always(or at least the ones i have seen) have imperfections, if they have polished sides they should be ok.
Old Oct 26, 2003 | 03:17 PM
omega11855's Avatar
which sides are you talking about the edge where it meets the cam caps?
Old Oct 26, 2003 | 03:22 PM
Kataku2K3's Avatar
Default Re: took apart the motor (mmuller)
MANUAL FOCUS??? hehe, j/k Anyways... You'll almost always have a little scoring but as BRUCELEEROY said, if they aren't too deep and really bad just have them line honed... If they have sharp edges I'll normally just debur with ~1000+ ge\rit sandpaper... Otherwise I really wouldn't be too worried, you can plastigauge to check clearances if you wanna check spec... Also in the future I would just refer to your cam "bearings" as the journals... That's what they really are and it just easier to understand... Oh well, not a big deal... Just my $0.02
Modified by Kataku2K3 at 10:06 PM 10/26/2003
Old Oct 26, 2003 | 03:30 PM
omega11855's Avatar
sorry about the technicality i forgot the word(journal so i figured it was a bearing sorta so i put that down)
Old Oct 26, 2003 | 08:51 PM
SYD's Avatar
SYD
Default Re: took apart the motor (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote"> but as mmuller said, if they aren't too deep and really bad just have them line honed...</TD></TR></TABLE>
hey i said that!..
Old Oct 26, 2003 | 09:05 PM
Kataku2K3's Avatar
My bad, I wasn't even paying attention... I'll have to change that... Sorry
Old Oct 27, 2003 | 07:36 AM
SYD's Avatar
SYD
its all good
koczeka
43
Apr 5, 2014 04:57 AM
Corksil
20
Jun 11, 2010 08:37 PM
91-lsvtecsi
Dec 8, 2008 04:27 PM
s_18
Jul 3, 2006 08:13 AM
Mighty
Jan 11, 2004 03:57 PM
